I see features on this but I need step by step instructions on how to do it. Wiki doesn’t have it and I can’t find simple instructions anywhere. What I do find are sketchy details, but they are only flashes in the night. I’ve even had this working before but its been about a year and I can’t remember how to do it. I don’t need to record everything but rather just a show or two now and then. Would appreciate a step by step run through on how to do it. I have the files I need but can’t remember how to use them. Can you help?
Thanks,
Steve
Do if you have a question or suggestion, post it here because I’ll get a notification and will try to respond.
CycleJ, the developer for Tablo Ripper, asks you to post in the Tablo Ripper posting, and he’ll get a notice and likely respond if/when possible ![]()
Hi,
Been using the ripper for some time now and find it to be fantastic. thank-you cyclej for your hard work on this.
Unfortunately for me I had to ungracefully shut down my computer, unrelated to tablo ripper but upon booting up again I noticed that tablo ripper has lost all of its history of ripped recordings. it would take quite a while to manually tag each recording to “not new” - is there a config file that tracks this ,that I should have backed up?
more generally is there a faster way to mark a few hundred recordings as “not new”?
As said previously, @CycleJ, the developer for Tablo Ripper, asks you to post in the Tablo Ripper post, and he’ll get a notice and likely respond if/when possible…
If you haven’t had a chance, take a look at the configuration guide. What you’re looking for is the “Sync” button, then you can individually mark any new recordings you have’t already ripped.
And @Nilex is right, I only get a notification for posts to the main Tablo Ripper topic.
thank-you that (sync) slipped by me; the app has been so dependable I haven’t had to think about this problem before!
Hi, I have the older quad TABLO. I want to download the latest TabloRipper, but You have deleted the link. Is there a site where I can download the last iteration?
Welcome to the community. Check out these posts in the main thread:
Thank you so much for the link. The app is working for me. Is there a chance to get the source code? I’d like to try making some customizations but have no idea as to how to find my tablo on the wifi.
I doubt that @CycleJ can release the source code since he had to sign an NDA to have access to the Tablo’s inner workings. Also, since most of the Third Party App developers have pulled their apps for the Legacy Tablos, I’m guessing that the New Tablo company no longer wants to encourage Third Party apps or help with their development.
SurLaTablo isn’t “pulled”, just saying. While I don’t use it like I used to, it still functions for OG Tablo units. Does still require Python 2.7 though.
You’re welcome. I recommend you try out Tablo Tools as an alternative first.
