Is the Tablo Engine the same thing as Tablo Preview or use the same guts? I couldn’t scroll around in Tablo Preview and had to go back to the original Tablo app after the update. Multiple reboots didn’t help.
I saw a message a couple months ago about getting into the beta group to get early access to new features. Does the beta work with Pie? If so, how do we get access?
It seems this thread is just about the Tablo ENGINE DVR app and Pie, not the Tablo app or Tablo PREVIEW app which are used with the standalone Tablo DVR boxes.
My nVidia Shield is running Android Pie and I am not having any problems accessing either one of my Tablo units using either the Tablo app or the Tablo Preview app.
As @theuser86has indicated, the warning from @TabloTV was for the Tablo Engine and Android Pie combination.
You people weren’t warned by Tablo before NVidia released the update that tablo engine was going to bust yet you’re baffled that I am trying to find out if the same thing could happen with their other apps.
You can’t just assume things are going to work with tablo since they weren’t even capable of stopping this from happening when Pie has been out on the adt-2 for a year.
There is currently a Beta ongoing. A lot of new features that put it on par with the current other Tablo apps. I’d contact support directly on Monday and see what they can do for you.
Hey folks - We think we’ve got a fix nailed down that we’ll be distributing to our beta team soon. If they give a thumbs up we’ll distribute it to everyone shortly thereafter.
