An update to the 4th Generation Tablo app for Roku is now available. While there aren’t any big new features, there are a lot of under-the-hood bug fixes and improvements that should provide a smoother experience, especially around Offline Mode. We also increased the font size on the channel numbers in the Live TV Grid for those who were squinting on the couch.
I was really hoping that the ability to hide the timeline bar [2] would have been part of this update, but it appears that it is not. @TabloTV , could you please advise if / when we might have this added to the Roku app?
@TabloTV
REPEAT, repeat request! I have 3 Tablos and I primarily use the G4 Roku interface. I really want Tablo to make my life easier. All I want for now is to have some indication ot which of the 3 is selected when I turn the system on without having to manually scroll down to settings every time.
Either: give me the ability to hold down the navigation button to scroll down to settings. OR put the name of the unit at the top of the home page.
I thank you in advance for giving me this convenient feature.
@TabloTV
Since this update, fast forward has problems. I Start playing a recording and the fast forward doesn’t work. I hit the back arrow, then select the recording again and select resume. From then on, the fast forward usually works correctly for the rest of the program.
@TabloTV why would you guys add yet another step to select a channel from favorites? The whole point of favorite channels is to quickly get to those channels. Now, instead of going to the channel when I select it, it asks if I want to record or go to the channel. The UI should be more streamlined and getting to channels shouldn’t be so tedious.
Yep – same for me - - fast forward, step forward, rewind, ALL REALLY SCREWED UP in the latest update. Start playback, attempt to step forward and it frequently stops responding to the remote – the light on the Roku shows it’s clearly GETTING the remote commands, but the app stops responding. SAME behavior near the END of recordings – app stops responding to the remote.
COMPLETELY BROKEN.
