The show converted without any issues. The file name “Late Night With Seth Meyers - s02e148 - Actress Kristen Wiig; actor Tituss Burge.mp4” was picked up by MCEBuddy and converted. Now I just need to have MCEBuddy remove the commercials without cutting any of the show. Thanks again for the great app. I really like the fact that you can start it as a service and forget about it.
I have been using the latest ver (1.0.2) with zero issues today. Thank you for all the additional functionality added over the last two weeks. One item i thought you might be adding is either a channel number or network ID (ABC, FOX etc) to enable the use of custom INI files with MCEBuddy for more precise snipping of commercials. Is that something coming soon or did i just dream it? Regardless, its very cool tool!
After playing with the latest release (1.0.2) it’s working great for me and does everything I need. I played with MCEBuddy but don’t anticipate using it, at least not frequently. I have a couple of nice-to-have suggestions, and then an idea for a new feature.
In the nice-to-have category, it would be nice if when a new version is installed, it retains the paths to ffmpeg as well as the output folder, and also it would be nice if it deleted the previous version. I just ran the installer and noticed 2 versions of TabloRipper on my desktop. Maybe if I had uninstalled first, the paths would have been preserved as with previous version, but I didn’t try that. Not a big deal, but would be nice.
In the new feature category, it would be neat if progress bars (0-100%) could be implemented both for the program currently being downloaded, as well as an Overall Progress (0-100%) bar in the case where multiple programs have been selected for download. Improving on this, it would be nice to have an estimate of remaining time for each.
Thanks for the feedback! Please give the latest version (1.0.3) a try. It addresses your issues, but not all your suggestions (yet).
Just found this thread and I can’t wait to try it out.
I also found another program that will automatically cut commercials. So Tablo -> Tablo Ripper -> Commercial Cutter -> Plex = amazing.
Which commercial cutter would you recommend?
I’m using MCEBuddy and it seems to be working quite well.
It does work well, but it takes a LONG Time. I usually do the conversions overnite so it doesn’t tie up my computer.
Chas
I have it running on my Plex server so it is always waiting to receive new files. But yeah, it does take a long time, especially if you want a high quality end file.
@CycleJ I love your software. I’ve installed the latest release and it works great, but I have an issue on Windows 8.1. The GUI window is smaller than the content so I can’t see or access any of the buttons in the bottom row and the window is not resizeable. I tried this on my Windows 7 and Windows 10 PC’s and it displayed fine. It’s just on my Windows 8.1 PC. I can work around the issue though. I just go into the properties of the shortcut and specify to open the window maximized.
I’ll have to try that on mine when I get a chance. My old laptop ran Windows 7, and I recently updated to Windows 10. Tablo Ripper ran fine on both. I’ll give it a try on my Windows 8.1 Tablet and report back my results.
The problem is that the stored screen size and position is out of sync with the software version. The easiest way to fix it is to find the ‘settings.xml’ file under c: program data, Tablo ripper, and delete it.
You’ll have to reconfigure the app, but you’ll see the full screen.
Works perfectly on my Win 8.1 tablet, exactly as it did on Win 7 and Win 10.
Can somebody explain what the “Install Services” button actually installs?
Many thanks,
Larry
There are two program executables. The desktop shortcut runs the GUI, which allows you to configure the application, rip new shows using optional filters, or rip user selected shows. All that runs on the foreground, which means the program has to be open.
Installing the service registers the background service with Windows and requires administrator permission to complete. Once installed and running, it’s available to rip new shows using optional filters in the background. You don’t need to be logged in.
You can select if you want to rip in the foreground or background using the GUI as only one program can be active at a time to prevent conflicts. If the background service is running you can stop it to rip in the foreground. There’s no need to uninstall it.
Great explanation @CycleJ for a truly well done and useful program, or more accurately stated, a pair of programs ! I really want to thank you on behalf of the Tablo community for providing a much needed and very much appreciated resource with this ripper. Bravo !!!
Larry
Downloaded this latest version yesterday and seems it is not working fully. It took maybe a minute to come up after launched. Once up, I set it to rip as I have with earlier versions and it started. Came back a few hours later to see it stalled and it went into some kind of full screen but only the background went to full screen. All the text was in the top left corner the same size it was before I left it. It was locked up so I had to do a CTRL-Alt-Del to close it. Tried it again this morning and it took about a minute to load and came up in that same full screen configuration as before. I do think some pretty important pieces are missing. Had to uninstall it.
Seems like a few people have been having trouble with the “fixed” window size, so I changed the window to be resizable.
And for reasons I don’t understand, sometimes the Nuvyyo server is really slow responding to a request for a list of your Tablo devices. So I added an option to bypass that request IF you have a static IP assigned to your Tablo.
I do have a really large timeout value associated with the Nuvyyo server request, so I suspect that’s why it appears the app “hung up” when you started it. I’ll try to remember to reduce that value and fail “sooner”.
Meanwhile, try out the latest version when you get a chance,
Feedback is always appreciated. Thanks for all the helpful remarks and suggestions.
Thanks again CycleJ for the fast responses you have to your customers. This latest version (v.1.0.6) seems fine, ripping as I type this. I am running the background service, I presume this means TabloRipper will do it’s stuff whenever there is something to be done, within the time times selected. If so, that is good as I have the times set for 00 to 24. I only see 7% to 8% CPU use, so I see no need on this system to have it off, unless there are conflicts in some way. We’ll see. The option to use a static IP is a good one, as most of the time IP’s remain the same. Most routers have the ability to hold specific IP’s to a device anyway, so I believe this will be the best option. Load time is still about 45 seconds after startup, but if it runs in the background most always, it really makes no difference.
I have to say you have a fine piece of work on your hands.
Edit - Forgot to mention, I am ripping 30 to 1. In other words, it takes 1 minute to rip 30 minutes of content. I am a videographer and do quite a bit of editing/rendering, and can say this is fast. Quality is as good as the original and I can use this format fine in MCEBuddy to remove commercial content if I choose.
-Rodger
You’re definitely a power user! And correct in your assumptions regarding the background service.
One suggestion - consider scheduling the background service to only be active at the end of your recording day. That way any CPU drain won’t affect your normal PC use.
A side benefit is that MCEBuddy can’t start until TabloRipper finishes, and that’s a significant drain on your CPU.
Again, many thanks to everyone that’s helping make this a useful program. Keep the comments and suggestions coming.
