Please run it with -debug and lets see what that returns
I don’t know anything about any Chrome issues. What firmware are you on? Maybe your DB is corrupt, might need to contact support
When I use Internet Explorer my Tablo comes up really fast and all shows are there so I don’t think anything is corrupted on the Tablo itself.
I’m not sure what is needed for the debug output, There seems like too much text to post. Is there a way to do private messages here? Or email?
My Tablo: (Firmware Version: 2.2.12 build: 1629814) (Model: Dual tuner)
Yep, just click on my name and hit message
I sent log output but I’m wondering if maybe it’s irrelevant. Using VLC, I used the URL for the video stream from the log output and none of the old addresses worked but the newer one did.
There is a new version uploaded that takes care of a couple issues. If you are having issues exporting please download
Jestep,
Getting 404 errors when trying to export some videos. Video plays fine from web app. Any help greatly appreciated.
debug log…
[http @ 0x7f8faae004a0] HTTP error 404 Not Found
http://192.168.11.13:80/stream/pl.m3u8?2FmK3it1Gjs_CCx2dlmV2Q: Server returned 404 Not Found
Error code received was 1
End Time:11:17:14 AM EST
Total minutes processed 0
Not Completed!
Need you to run via command line with the -debug switch so I can get the info I need
Here is the output after selecting export. Please let me know if you need a full log from the start of the app. Thanks!
Done Loading Data for Tablo (Firmware Version: 2.2.12 build: 1629814) (Model: Quad tuner)
Tablo : Tablo (Firmware Version: 2.2.12 build: 1629814) (Model: Quad tuner) - 192.168.11.13 - 471480
sanitizeFilename:/Volumes/5T/temp/torrents/complete/TV Shows/Modern Family/Season 08
sanitizeFilename:Modern Family - s08e10 - Ringmaster Keifth.mp4
/Volumes/5T/temp/torrents/complete/TV Shows/Modern Family/Season 08/Modern Family - s08e10 - Ringmaster Keifth.mp4
Sat Feb 04 16:39:05 EST 2017
-delteted-://192.168.11.13:80/stream/pl.m3u8?2FmK3it1Gjs_CCx2dlmV2Q - Modern Family - s08e10 - Ringmaster Keifth.mp4 - OS Mac OS X
Start Time:4:39:09 PM EST
ffmpeg version 3.2.2 Copyright © 2000-2016 the FFmpeg developers
built with Apple LLVM version 8.0.0 (clang-800.0.42.1)
configuration: --prefix=/usr/local/Cellar/ffmpeg/3.2.2 --enable-shared --enable-pthreads --enable-gpl --enable-version3 --enable-hardcoded-tables --enable-avresample --cc=clang --host-cflags= --host-ldflags= --enable-ffplay --enable-libass --enable-libfdk-aac --enable-libfreetype --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libxvid --enable-opencl --disable-lzma --enable-nonfree --enable-vda
libavutil 55. 34.100 / 55. 34.100
libavcodec 57. 64.101 / 57. 64.101
libavformat 57. 56.100 / 57. 56.100
libavdevice 57. 1.100 / 57. 1.100
libavfilter 6. 65.100 / 6. 65.100
libavresample 3. 1. 0 / 3. 1. 0
libswscale 4. 2.100 / 4. 2.100
libswresample 2. 3.100 / 2. 3.100
libpostproc 54. 1.100 / 54. 1.100
Trailing options were found on the commandline.
[http @ 0x7ff896602980] HTTP error 404 Not Found
-deleted-://192.168.11.13:80/stream/pl.m3u8?2FmK3it1Gjs_CCx2dlmV2Q: Server returned 404 Not Found
End Time:4:39:14 PM EST
Not Completed!
Ok, did you download the latest ver? I put it up maybe a week or so ago
I think it has to do with extra data that gets stored
Also maybe try this version it will spit out a bit more
Yes, I had grabbed the latest.
Here is the output from the test build you posted.
Sun Feb 05 08:40:03 EST 2017
http://192.168.11.13:80/stream/pl.m3u8?2FmK3it1Gjs_CCx2dlmV2Q - Modern Family - s08e10 - Ringmaster Keifth.mp4 - OS Mac OS X
Start Time:8:40:05 AM EST
**** BEGIN COMMAND ****
/usr/local/bin/ffmpeg
-i
-strict
-2
-af
volume=10dB
-crf
25
-metadata
title=Modern Family - Ringmaster Keifth
-metadata
show=Modern Family
-metadata
description=Modern Family - Ringmaster Keifth
-metadata
comment=
-metadata
year=0004
-metadata
episode_id=10
-x264opts
bluray-compat
**** END COMMAND ****
[http @ 0x7feec2401000] HTTP error 404 Not Found
End Time:8:40:10 AM EST
Not Completed!
Ok uploaded a new test, not sure it will fix anything, but it should show me a bit more
latest build
Mon Feb 06 09:32:06 EST 2017
Start Time:9:32:11 AM EST
-i
-strict
-2
-af
volume=10dB
-crf
25
-metadata
-metadata
show=Modern Family
-metadata
-metadata
comment=‘N/A’
-metadata
year=2017
-metadata
episode_id=10
-x264opts
bluray-compat
[http @ 0x7fd72ef005c0] HTTP error 404 Not Found
End Time:9:32:16 AM EST
Not Completed!
What happens when you just put the URL in a browser:
page output
404 - Not found
nothing else in the source page delivered.
oh Interesting. Mine will download. Might need help from @TabloSupport on this one
What is the request that I make to @TabloSupport? I can play the video from the web interface. Just not sure what I would ask?
Thanks for helping with this.
I need them to look at the URL. If you are only having issues with this one episode, something must be going on I cannot see. They will get the notification they were tagged here.
So do me as favor, delete the recordings.db and then try and export the one video again
That seems to of fixed it. The file is exporting now. Were you able to determine the issue?
