FYI, I have a version that caches the data on the newer versions of Tablo. The first time will take some time, but after that should be pretty fast. See the following example:
PRE-CACHED DATA-
Loading Data for Estep Tablo (Firmware Version: 2.2.10 build: 1615114) (Model: Dual tuner)
Opened database successfully
Total Shows: 456
Time in seconds: 51 seconds.
Time in minutes: 5 minutes.
Time in hours: 0 hours.
DB Connection Closed!
Done Loading Data for Estep Tablo (Firmware Version: 2.2.10 build: 1615114) (Model: Dual tuner)
POST-CACHED
Total Shows: 456
Time in seconds: 2 seconds.
Time in minutes: 0 minutes.
Of course as always, this is beta but give it a shot if you want
I have used the new one. It extracts just find, however it only finds 4 of my 5 recordings.
The Tablo shows 5 (on Safari and Apple Devices) but the exporter shows only 4. The missing one is 2+ hours long and I am able to watch it . Its the third recording on my tablo, alphabetically its the first in my OS lists.
Ran OK listing all the shows (300 of them) except one, exported those I wanted OK. Got this error message on that single exception\show (from PBS):
Loading Data for Tablo (Firmware Version: 2.2.10 build: 1615114) (Model: Dual tuner)
Opened database successfully Error getting data for Down the Dixie Highway -
h**p://192.168.1.19:18080/pvr/238261 JSONObject[“description”] not a string.
h**p://192.168.1.19:8885//recordings/series/episodes/238586
JSONObject[“description”] not a string.:{“background_image”:{“image_id”:214385,“has_title”:true},“cast”:null,“tms_series_id”:“11996638”,“awards”:null,“tms_id”:“SH022386700000”,“description”:null,“episode_runtime”:5400,“cover_image”:{“image_id”:214384,“has_title”:true},“title”:“Down the Dixie Highway”,“orig_air_date”:“2015-08-18”,“thumbnail_image”:{“image_id”:214383,“has_title”:true}}
It looks like I have to a complete reinstall every time a recording is missing from Tablo Exporter’s list. I am running 0.07 build 106 on my mac. I’m also finding that the export seems to be a lot slower with the download from note 807. So far I have installed this from scratch 4 times today.
You don’t have to install from scratch, since there is not install anyway
If you are talking the time it takes to populate, yes it is because we have to change the way we pull the data from Tablo. But, this version caches the data after the initial load.
As I said above:
PRE-CACHED DATA-
Total Shows: 456
POST-CACHED
Total Shows: 456
I am looking at the other issue now
If you are not seeing all the shows run the program from command line as java -jar (the path to the jar file)\ or / depending on os TabloExport.jar -debug
Yes, what I meant is that I would unzip it again and run from the new folder. When I ran a second time from the same folder is when programs would disappear. It appears that it only found them when it built the db, but not when it updated it on subsequent runs.
I only keep a few files, my routine is to export them daily then delete on tablo. I wonder if those with large list of programs even notice a file or two might be missing from the list?
The only reason I found some files missing (two actually) is that I ran the program in terminal mode which showed files (246 of them) on the Tablo but 2 not picked up for export due to missing elements. Error messages were showing for them in the terminal box that don’t show up in the GUI screens.
The reason I ran the program in terminal mode was that I was getting a Java error initially (missing Java package) and wanted to see what I was missing on my computer from the Java installation. Otherwise I might not have detected the two missing shows.
