Yea, it will mean a lot more coding that I am not currently doing and you could use other processes to do that ;)
True but I like where you are going with this app … :-)
@ericgus, yes and if you saw my reply above::
This looks great so far! .. exactly what I have been looking for .. but I did notice its chewing up CPU like crazy during the download .. I presume you are "converting" to mp4 in the process.. anyway we can just get the "raw" ts stream dump to a file .. I prefer to convert it to my own preferred formats (one which is a weird divx variant used by our in-car video headrests) and another is a custom AppleTV format I prefer for my Plex server) .. (both of which I already have Handbrake templates for) .. so I wouldnt need or want this tool to convert it since I will be converting it again anyway and I would prefer not to encur even more "loss" to the video if possible..
Just what I was going to suggest. If you stick with raw TS this conversion will be far faster and lossless. It will also allow further filtering to be done faster and more accurately such as automated commercial removal.
@marjamar like I said, there are other ways to download the ts files. No plan on adding that into this
@ericgus, yes and if you saw my reply above::@ericgus about the sync issue. This is interesting. I did notice if I was using the computer at the same time doing other stuff it had some issues. Maybe try not doing anything else?Also, maybe the slow down might help, just not sure I wanted to do that.
My computer wasnt doing much of anything else … the cpu usage was high but never hit 100% … maybe 75% across all processors…
what I think might be going on is the source TS stream might not be 100% clean and your encoder doesn’t know how to cope with a signal hiccup.
@ericgus, yea I am working on it
no prob … totally understand this is pretty “alpha” software… but it looks great so far… I think you have a great foundation with what you have now.
OK, thanks.
@ericgus download the newest version see if that fixes the sync issue and the cpu usage.Thanks!
No didnt change anything but the download too significantly longer.
@ericgus, are you saying CPU was still high? The length of time it takes is due to lowering cpu usage.
@Jestep if nothing else this helped me figure out why the VLC plugin wasnt working … that same corrupt directory with the missing meta.txt file … I fixed it and now its working again so thanks!
Great to see this tool. I have Win7. In my case, shows 2x Tablo units (I only have a single unit, a 4-tuner). When I double-click either, nothing happens. Updated to latest Java.
Looks promising. I don’t see any of my manual recordings in my list.
I tested it with a news show and it worked first time on Windows 7. Easiest setup so far.
The audio slipped on a longer movie
I saved Gotham Episode 18 and at the 33 minute mark the audio was significantly ahead of the video. The degree it was out of sync made it unwatchable. I watched it on the Fire TV directly from the Tablo and the audio was in sync. Must be the conversion process. Going to try a second file now. I shall report back.
Note the computer was not being used for anything else during the transcoding process.
