I’ll give it a shot and let you know how it went.
Weird … i am not showing any recordings beyond Feb 20, 2015 … is there some kind of internal limit for how many shows are displayed?
@ericgus no, I am guessing maybe an issue with some meta data. I needed to handle that thanks. Download the latest I just uploaded and run via command line and send me the error via PM
Ok, should have continued on though right? Or should I say loaded all your data
No … would seem it died right when it hit that …
@ericgus you sure you got the latest? It catches that and ignores, but prints out the exception
I can redownload it again but is there any command line flag to show version to verify? . (I only downloaded it a few mins prior to my first post above)
@ericgus, might have been my mistake, just uploaded a newer version hopefully that won’t stop, but should still print the error
Ok … I must just have grabbed the older one … re downloaded it and NOW its working … showing all the correct episodes … (I am still trying to figure out what show that was that failed and/or how to delete it since it just seems to only be 5 seconds of video (its from PBS … that much I can tell) …
@ericgus, does it show up in recordings on the Tablo App??
thats what I am trying to do … the only thing around that time frame is a thomas the tank engine episode… which would more or less fit … but the timestamps seem off.
This looks great so far! … exactly what I have been looking for … but I did notice its chewing up CPU like crazy during the download … I presume you are “converting” to mp4 in the process… anyway we can just get the “raw” ts stream dump to a file … I prefer to convert it to my own preferred formats (one which is a weird divx variant used by our in-car video headrests) and another is a custom AppleTV format I prefer for my Plex server) … (both of which I already have Handbrake templates for) … so I wouldnt need or want this tool to convert it since I will be converting it again anyway and I would prefer not to encur even more “loss” to the video if possible…
I also noticed the converted/downloaded video has some audio sync issues not present with the web playback from the tablo app.
@ericgus I am doing a fast download and convert. I could slow it down during, but kind of defeats the purpose of what I was doing.
@ericgus about the sync issue. This is interesting. I did notice if I was using the computer at the same time doing other stuff it had some issues. Maybe try not doing anything else?
@ericgus I am doing a fast download and convert. I could slow it down during, but kind of defeats the purpose of what I was doing.And no, not going to download the ts files, again not what my purpose was. However, I do plan on allowing other formats. Not sure Dvix will be one of them however.
The divx format is so odd I doubt you could get it right … it took me a lot (and I mean a WHOLE LOT) of screwing around to get a video format the head rests would even touch (despite they advertised em as mp4 compatible – ha!)
@ericgus yea I have heard that, although could they use avi?
I was thinking something more along the lines of just a simple concatenated file. … without any parsing… it should be fairly simple to implement… perhaps a check box when you are prompted for a location ? … it doesnt have to be complicated…
Yea, it will mean a lot more coding that I am not currently doing and you could use other processes to do that
