Tablo Desktop Player (gen4)
I installed the Windows version (I’m running Parallels on my Mac), but when I try to stream a channel, nothing appears in VLC. It’s the latest version of VLC and my Mac has an M3 chip.
I think this is a question for @senke7su, but why don’t you just use the Mac version?
as @wysiwyggin mentioned, I would definitely encourage using the Mac version of the app (also needs VLC installed on the Mac).
Usually when people get blank screen it’s because they have the 32-bit version of VLC installed instead of 64-bit. But I have no idea what you’re using in Parallels. Do you have x64 Windows or ARM Windows? And does the VLC version also match? Lots of complications, native Mac version would be much easier :slight_smile:
@senke7su When I start to install on Windows it flags as Unknown Publisher. Also, it looks like the source code is not open source where we can verity to ensure not harmful to our computer. Any way you can make it a open source code so that we can install it as trusted software? Thank you in advance!
Sorry, I’m not able to at this time. It wouldn’t get rid of the untrusted publisher warning in Windows anyway, But you are welcome to upload it to VirusTotal (other folks already have as well) or any other virus scanners. It makes no connections other than to Tablo services and your local unit. Been downloaded 1500+ times. I literally just made this for myself because I was annoyed there was no desktop app and figured I’d share it with the community.
@senke7su
New here. Any chance of a desktop app for Intel Macs?
@senke7su
I’m having a couple of problems.
First, it isn’t updating the list of recordings. I have a couple dozen that it doesn’t show.
Second, downloads don’t work. I have to cut-n-paste the command from stdout and use the stock ffmpeg to accomplish it. I don’t see any errors on the Player’s stdout or stderr either.
It looks great, just not completely functional yet.
Also, how do you access the Tablo without getting the cloud token?
I couldn’t sleep last night, so at 3 a.m. I used Claude to vibe-code a Linux version entirely in Python. Since it’s Python, you can review the code and see exactly what it does. It worked for me, so I published it on GitHub—sharing is caring!
It should now work on more devices and operating systems, including Windows 11 and possibly macOS, though I haven’t tested it there. VLC works better, but I removed the dependency, and I’ve added support for a few other use cases.
I don’t plan to maintain or support the project, so if you run into issues or want to add features, feel free to use Claude—or your favorite AI—to troubleshoot and make changes yourself.
github[.]com/crash101g/TabloTV-Linux-Desktop-Player
Your Tablo. Your Linux PC. TV Everywhere.
Bring Tablo live TV to more screens around your home with a lightweight, flexible player built primarily for Linux.
  • Made for Linux: Tested on Ubuntu 26, Pop!OS COSMIC, and Fedora 44, with support for macOS and Windows
  • Watch your way: Choose VLC, ffplay, your fav media player, or a web browser.
  • Stream around your home: Watch on various devices across your local network.
  • Packed with practical features: Command-Line menu via terminal shell or web browser interface, Browse channels, save favorites, check program details, create playlists, and use a guide with compatible IPTV apps.
  • Flexible by design: Run it on your desktop—or on a headless home server, mini PC, or virtual machine.
  • Ready for real-world setups: Recovery features help reconnect after interruptions, and offline mode supports local-network viewing when internet access is unavailable.
  • Open and auditable: The complete multi-platform Python source code is on GitHub, ready for you to inspect with full easy to understand comments to adapt
  • Shared with the community: This is an unofficial project, provided as-is and not actively supported.
Want an even fuller-featured alternative to the official app? Take a look at JoeDV’s WebApp called TabloView, an open-source project for 4th-generation Tablo devices, and the TabloTV community discussion. It aims to bring together a broad set of features, including a program guide, live TV grid, recording library, and scheduled recordings. His was initial written for Windows (free official app is the Microsoft Store), but he just ported it to macOS and Linux.
More Screens. More Flexibility. Your Tablo, Your Way!
cool stuff @crash101g ! FYI the reason it’s so big is as an electron app, it’s essentially a full chromium browser packaged with my code. this made cross-platform releases super easy to do and work (more or less) identically on all 3.
@senke7su I just became aware of your app and it looks great for my primary use case (transcoding recordings to a local hard drive array). Thanks for a great app!
One question: Is there any way to modify the ffmpeg parameters used in download transcoding? I’d like to be able to use Intel QuickSync Video (QSV) hardware-based decode/encode to speed up the transcoding process.
Hi. Great idea for an app. It would be great to watch thru the tablo on my Mac. Am I missing something though? My M3 mac won’t install the app due to privacy or malicious intent concerns. OS is 27, Golden Gate 27.0.1,
I got @joedv"s app working on my Mac Mini M2 chip running Tahoe. have you tried on your Mac?
**No guarantees that this will work for your Mac as I recreated this from memory after much trial and error **
Installing joedv’s WebApp-TabloView
1. Open GetHub Release TabloView 1.2.3 · JoeDV/TabloView · GitHub
2. Under Assets click on link below to download the app data. I just kept mine in Downloads folder.
https://github.com/JoeDV/TabloView/releases/download/v1.2.3/TabloView-1.2.3-mac.zip
3. Under Downloads click on MAC.md to open and view
4. Open terminal on your Mac
5. Click on link to open/install Homebrew https://brew.sh/
6. By the rocket ship on the Homebrew page copy the line of code by clicking on the two little squares on the right of the code line on the webpage. This will copy the code line to clipboard.
7. Paste that line of code into Terminal, then follow the instructions
8. To install Python and FFmpeg copy/paste this command into Terminal:
brew install python@3.12 ffmpeg
This should get TabloView installed. To start TabloView modify the command below to match YOUR USER NAME and SAVED FOLDER location if you saved in different place than downloads. Then paste into Terminal and hit enter. TabloView should open.
"bash /Users/YOUR USER NAME/SAVED FOLDER/TabloView/start-mac.sh; exit”
From the directions the link MAC.md:
The first time, it spends a minute setting itself up. Then TabloView opens in your browser at http://localhost:7070. Sign in with your Tablo account; the first sync of your recordings and guide takes a minute or two.
  • If macOS asks whether to allow Terminal or Python to find devices on your local network, click Allow. Otherwise TabloView can’t reach your Tablo.
  • Keep the Terminal window open while you use TabloView. Press Ctrl+C or close the window to stop it.
  • Next time, start it the same way. It skips the setup.
I also made a script and saved as application/shortcut on my desktop to save a couple of steps to start it up. Using Script Editor. Modify the command with your user name and folder location from above.
tell application “Terminal”
activate
-- This opens a new window, runs your script, and leaves it open
**do script** "bash /Users/YOUR USER NAME/SAVED FOLDER/TabloView/start-mac.sh; exit"
end tell
@Chazbury, Thank you! I was able to get Joedv’s WebApp (TabloView) working. Appreciate it.
Glad it worked for you. I haven’t really spent time running it, but it seems to be an excellent app.
app works great on mac (ARM/silicon, M1 pro).
Can I plug the hard drive of the tablo DIRECTLY to the computer? Or do I still need to go through the Tablo app (by way of the Tablo Player app)?
No. Hard drive is part of the Tablo (storage). Tablo View is only an application to playback the recording on the computer instead of TV or tablet, or phone.
unfortunately not at @Chazbury said. when you attach a drive to your Tablo and initialize/format it, it is locked in and Windows/Mac can’t read it. But fortunately both my app (Tablo Player) and joedv’s app (TabloView) allow you to download all of your recordings :slight_smile:
[nerdy details warning]
You (probably) wouldn’t want to anyway, all of the saved video is a bunch of small raw MPEG2-TS files that you wouldn’t be able to make sense of. When you watch a recording, the Tablo itself re-constructs those files into a .m3u8 video stream that is played by the Tablo mobile/TV apps
