Spare Power Supply?
I just recently purchased a two tuner model Tablo, and so far I like it. I would like to take it with me in an RV, and would like to purchase a second power supply so I don’t have to take that back and forth. Does anybody have a part number for a suitable replacement power supply? I saw a previous thread where Tablo listed a Mouser power supply for the 4 tuner model (and a note that said the two models used different power supplies). But that model listed is obsolete.
Thanks.
I agree Tablo company should provide an option to purchase a spare power supply. Some problems with the Tablo DVR have been traced to defective power supplies and the ability to swap out with a spare would be very helpful.
In the grand scheme of things the cost of a spare power supply is minuscule compared to the overall cost of the system and would be a good investment.
Folks report using the Kensington K38047US for netbooks - $10 on Amazon as a replacement. Seems the power supply can go bad and make your Tablo appear dead!
See: Tablo has failed and is dead
I bought this one on eBay and worked great. Brought my Tablo back to life.
http://www.ebay.com/itm/AC-Power-Supply-for-2-amp-4-Tuner-Tablo-DVR-Wall-Mount-Adapter-12V-2A-Replacement-/292018426259?
I tried it on both my 2 Tuner and 4 Tuner and it performed well.
I got one for a spare, note that is has a usb port for powering a fan; just be sure to reset the voltage to 12 volts and use the right size tip.
Thanks for the suggestions. I ordered the Kensington power supply referenced above, and will give it a try on our next trip.
I ordered the Kensington power supply as well, and am using it now with my TABLO 4 tuner model. So far so good. I am keeping the original PS for backup.
Very important to change default 19 volt setting to 12 volts before powering up the Tablo.
My cost for the Kensington PS was $11.99 plus free shipping with Amazon prime.
I got mine from the same place, same price. Thanks for the tip on the voltage setting. I did see on the box that it had three different voltage settings. Nowadays I would have though the default setting would be 5 volts for all the USB devices.
I assume the voltage setting does not affect the voltage at the USB port?
Same here. Thanks for info
This is the type of connector that Tablo uses.
DC Power 12V 5.5mm x 2.5mm Barrel Male Plug Connector
So if you can find a power supply with that connector and enough amps, it should work.
I use the above connector to hook the Tablo up to my 12v solar, battery source and it works great. I even have a USB fan plugged into the Tablo.
I also have my netwotk adaptors running this way. My Tablo will now record even with a black out.
Now I need a 12v TV.
Can someone confirm (or deny) that this part will work as a replacement power supply for my Tablo 4 tuner.
Thanks
