Roku playback problems
Thanks for your help. STILL NOT WORKING PROPERLY
Delete Tablo app on Roku, Restart Roku, the quick reset Tablo. Then reinstall Tablo app on Roku.
Tried all that still no luck. Thanks for trying
Tablo support ask for a video of what is happening but video file is too large to send in email.
Hi @mansonn,
You should be able to load it onto Google Drive, One Drive or other such service and send them a link to your video.
Or, you could also upload to YouTube and make it an Unlisted video so only those with the link can view it.
I’ve been having the same problem when I try to access All recordings on my legacy quad Tablo when using Roku. Started happening around mid May. I can see most recent recordings, but when try to access all recordings, I get booted out. I have Tablo with 2.2.60 and Roku 4850X-Ultra with software version 15.2. I can see all my recordings on my Samsung phone with the Tablo app. Have you found a fix for this problem of booting out when trying to access all recordings using Roku on the TV?
No luck here. I guess we just have to live with this problem and hope it doesn’t get worse. Seeing that Tablo legacy backup is ending very soon, just hope I can continue to record and play back. Being in Canada, cannot even access new Tablo units as they are not authorized for Canada. Seeing Tablo was invented in Canada and sold out to the States, seems they no longer need Canadians.
I had no problems purchasing, and having the Tablo Gen 4 delivered to my Canadian address, using Amazon Canada.
Any problem with programming or guide features
Just a shot in the dark, but do you have any series with over 200 episodes? There was a problem for a while that if you had a series with too many episode recorded, it would kick you out of All Recordings.
It was supposed to be fixed with 2.2.58 but it might have come back. I would check with support on this.
https://support.tablotv.com/hc/en-us/articles/201445216-What-Countries-Does-Tablo-Work-In
Regarding getting booted out on a legacy Tablo when trying to go to All Recordings using Roku…Yesterday I accessed my recordings on my Samsung phone through the Tablo app. I found an untitled recording in the list. This untitled recording had many many recordings from 2019-mid year 2026. I deleted all of them. I also deleted the last recording before I started having problems mid-May. I had read somewhere that there may be a corrupt recording that could cause the booting out problem, which is why I deleted the last recording I had and the mulitple recordings. Well…Problem solved!! I can now access All recordings on my legacy Tablo when using Roku. Not sure if the multiple recordings on the untitled recording or the last recording I had fixed the problem, but I’m happy it’s resolved. Fingers crossed that it doesn’t happen again.
Since I live in Brantford Ontario, I used my actual postal code for the channel scans. I don’t really have much to say about programming and/or guide features. They are somewhat satisfactory.
But it still has the two major headaches of the legacy units.
1/ Not able to retain previously found towers, and/or add towers when i use the, “Gasp!”, rotor.
2/ No live signal strength and signal quality meter.
Oh!
I forgot to mention, these ongoing problems.
and…
