I can’t believe that a year after I purchased my Tablo, I am still having such difficulties with both of the Tablo devices that I purchased. It is one thing after the next. The most recent issue is so messed up and wonky it is difficult to even describe. And Tablo’s suggestions are less than helpful.
I’ve wasted money and too much time on trying to make this work. Guess it is time to see what I can get on eBay although I feel kind of bad selling a product that continues to be so glitch.
It would certainly help if you described something about your troubles, if only which streaming device you are using. I’ve had my Gen 4 for about four months. Even on my four different Roku devices I have had few troubles. I canceled DirecTV and am saving more than $150.00 per month. My Tablo has better than paid for itself. I’m not going to pretend it is perfect, but I am really pleased with it.
I am glad that you are happy with your Tablo. I’m not.
As I said in my post, the (current) issue is so complicated it is hard to even explain it.
I’ll come back with more when I am able to put it into words. If I haven’t thrown both devices in the garbage prior.
Yea. It is real hard trying to find a possible solution, if they don’t know where to start. Try just sitting down and typing your problems and the things you have tried, we might just see something in your description of problems. No AH’s on the help side here just start typing.
OK. So I’ll do this piecemeal. Here is the latest issue. There are 3 live shows that I have a a series recording scheduled on CourtTV M-F. 9-11am, 11-3pm, 3-7pm.
Just now I was watching the recording of the 11am-3pm show. I had fast forwarded enough through commercials that I was watching live (around 11:30am). For some reason the screen went from streaming the show to the Home Screen. Now the recording is no longer showing up in “Latest” recordings or “All” recordings. It’s just gone.
UPDATE: I had 2 Tablo devices, Tablo 2 and Tablo 4. I had the same shows set to record on both devices. I was just watching that same recorded show on the 2nd device. Same thing happened. Switched to Home Screen and then recording completely disappeared.
I live with a disabling medical condition and I really don’t have the energy or brain power to be dealing with this. I don’t understand how they are getting away with selling a product that has so many issues.
Okay, I have a guess… I can’t explain why it would have exited the program when you got the end while still recording, I haven’t heard of that. However, there is a known issue where you watch a recording to its completion and it automatically vanishes from the library. As far as I know that is a Roku only problem.
In that case, if you open the Tablo app on your phone you should see the program in your library. Play just a few minutes of it on your phone, and it SHOULD reappear in the library in your Roku.
This is a known issue and Tablo is working on a fix.
PS. It might be obvious from my description, but on both devices it stopped recording the 11-3 show, despite in the program grid it indicating that it is still recording.
OK. So here is the latest issue. Similar to issues I have been having. I have 3 series recording set on CourtTV (not OTA, but built in channel). From 9-11am, 11-3pm, and 3-7pm. At the suggestion of Tablo support these were initiated on the iPhone Tablo app.
This morning around 9:30 I started watching (on my Apple TV) the 9-11a recording that was actively being recorded. When it got to approximately 49 minutes into the recording (I did some fast forwarding) the recording stopped and the screen went back to the Home Screen.
I see in “failures” the recording. It says “Unknown error. Check antenna and network connections.” This is not an OTA recording and my network connection is fine.
I have 2 tablo devices. Similar thing happened on the 2nd device. Only recorded 49 minutes, but there is no failure error.
Issues continue. Does anyone have any suggestions as to how to sell my two devices? I’m afraid to in conscience sell on eBay when the Tablo has so many issues.
As you can see in photos, shows recorded on both OTA channels (e.g. CBS) as well as built in channels (e.g. CourtTV) are being broken up. So clearly not an antenna reception issue. The channels are coming in just fine. The recordings have been initiated through the iPhone app, as has been recommended.
Today’s recording of CBS Sunday morning was really messed up. It is split into 4 short recordings — none of them watchable — and it did not even record until the end of show (1.5 hours)
Another (ongoing) issue is “No Tablo Found” when I try to access with Roku. This currently has been the case for a few days. I can, however access with the AppleTV app.
Both of these issues could be related to signal – antenna and wireless.
Run another channel scan and see how well your problematic stations are coming in. Try turning Tablo’s built-in tuner on or off and testing again.
As for wireless, try rebooting both the Tablo as well as your router. I know it’s a pain, but this can fix many connectivity issues – even if no other device is having an issue. To reboot your Tablo, press the button on the bottom of the puck once, quickly.
