Recorder programs while playing on rewind just pauses
In the. Library if you are watching any recorded program, and for some reason if you rewind and play , it just does not play. It is like it is stuck.
You have to exit and come cback and then it starts playing.
By the way i have a external seagate drive attached to extend the capacity.
It used to play before.
Looks like some programming issue from the developer side
What are you using as your streaming device? Roku, Apple, Google, Smart TV with Tablo app?Wireless or wired?
Samsung Tv Tizen OS with Tablo App on it
Check this out about Samsung TV. Perhaps someone on that thread Amy offer some assistance. NEW - Tablo Samsung TIZEN App (4th Gen) Update (v. 1.6.0)
Yes checked it out. The problem as i mentioned is tablo programming for Samsung Tv. This is only if you rewind a recorded show and then press play
I have the same issue on my Samsung 65" (also running TIZEN) and worked with Support for weeks until they said to wait for an update. The Gen 4 Tablo is at 2.2.56-2532914, the TabloTV app is 1.7.3. My last email with Support was April 18.
Hi @mjmorasse,
We did release Tablo LG webOS and Samsung TIZEN App (4th Gen) Update (v. 1. 7.4) - Announcements - TabloTV Community at the beginning of this month.
Try deleting your app and reinstalling it, it should be at 1.7.4.
