I would love to be able to quickly remove a number of items, which I can only do one at a time, now.
I don’t know what the best mechanics might be, but perhaps a long press on an recording could pop up a check box style selection window where you can select multiple items and then “Delete Selected” items?
You are correct that currently you can’t selectively delete a group of recordings using just your Tablo.
However, there is a way to do this using third party apps. I personally use Tablo Ripper developed by @CycleJ primarily to rip recordings from Tablo to be permanently saved to my NAS for viewing with Plex. Tablo Ripper is also capable of selectively deleting one or multiple recordings. It is simple to use and much quicker than deleting recordings one at a time.
Maybe someday this feature will be added, but until then I’ll just use Tablo Ripper for that task.
Yes, Tablo Ripper is a Windows program, but there are several other third party apps that run on different operating systems. Just check this forum for third party apps and I’m sure you can find something that will work for you.
Both APL Tablo and tablo-tools are GUI apps which run on multiple platforms while capto is CLI linux based, all of these allow for mass delete. as well as the previously mentioned SurLaTablo
OTA2GO is an android app - I have no experience and no knowledge of it’s features.
Well, IMHO it should be built in. I often watch 1 local and 1 national news, but I record them all. I simply want to delete all 6 of these, just a simple example.
Why not enable ‘keep x’ on news recordings then? If you set it to keep the last 1 or last 3 the Tablo will do the work of deleting the older news programs for you.
