@MikeNE I wonder if this is the same issue I see on Roku 3.
Hello Everyone,
@runkmoe there is an issue with Fire TV in the current version. I gave @Davidvr the fix but waiting for him to update.
@Jestep Thanks for the update. I thought i might be going crazy.
I cannot play live tv through Plex on my Roku’s. I can through the direct Tablo app on my Roku and that is what i am currently using to watch my recordings. I am also struggling to get the older Plex Tablo app to play my shows on my Amazon Fire TV as well. It will play some shows but not all.
Thanks for the updates and if there is anything I can do to help, let me know.
@runkmoe the Fire TV issue is a bug for the beta channel and probably the older version too…
@Davidvr... I extracted the zip file to the plug-ins directory. I don't see tablobeta showing up in the Channels...
Thanks,
Monte
@Monte did you restart Plex?
@Jestep… yep, but just the Tablo Channel shows up of the two… hmmm
Sorry guys, I’ve caught something and have been out sick trying to get better, as soon as I am I’ll get @Jestep 's fix in for the firetv and hopefully resolve some other bugs with the new threading I added.
@Monte do you mean you see two?
@Monte does it say beta??
Never mind… it showed up…
New to both Tablo and Plex. Setting up a home theater and looking at these apps to be part of it. Plex is pretty well mannered it seems and Tablo I believe is the key to TV in the theater. Still have many avenues to explore before I can pull together all the parts and pieces for hopefully a common, single interface to use in the theater.
As to Tablo and Plex, you channel plugin is working, but unfortunately it seems to lack the ability to pull valued info from outside sources such as IMDb and others to help fill in content to each recording. Also, it seems there isn’t any category or real sort feature to recordings, just lumped together. Tablo itself through the android app does this, but I don’t find a way to have it done using your Plex plugin. Am I missing something perhaps?
I appreciate all time and effort you have made producing this plugin. It is of value to myself and many others. I hope over the course of your efforts, the database structure does conform more to something like tablo uses on android.
Thanks again.
-Rodger
@marjamar The plex plugin only provides two views of recording, TV Shows, lists each show , Sports lists sports programing and Movies lists movies. The second view that it provides is the Recent recordings view, that lists all recordings no matter the type with the newest recordings at the top and the oldest toward the bottom. We only use information provided by the tablo to fill in details at this point because plex does not provide any additional meta gathering capabilities natively it would be difficult to read other sources.
Over time I will get the hang of this device better and your plugin as well. Thanks for the reply and help understanding your work.
-Rodger
First of all many many thanks for making the tablo plex channel! I hope tablo has you on the payroll, because this feature was definitely the reason I made the purchase.
So…everything has been just great until recently.
I’ve been having issues with plex on the PS4: I can run tablo perfectly on any other device with plex (Mac,iOS ect…), but when I run it through the ps4 browser (my main source) I keep getting the “problem playing” error on all of the channels. Also, there is no fan art on any of the channel’s, not a big deal, but this happened just before I lost the live tv function on the PS4.
Any ideas or remedies I should try?
Thanks!
I’m not sure if this falls in your area or not, but I’ll present it here. It probably doesn’t. It probably involves more Plex than your Plex Channel App.
