A new Tablo firmware hotfix update is on the way for network-connected Tablo DVRs. (This excludes the Tablo DUAL HDMI and Tablo QUAD HDMI).
Like all Tablo firmware updates, this is being distributed in a staged rollout over the next few weeks. A small number of customers will receive the update today, with more added to the rollout every weekday.
When your DVR is eligible for the update, a notification will pop up within most Tablo apps and will look like this:
Release Notes for Firmware 2.2.38
NOTE: Post-upgrade database processes (if needed) may take several minutes to complete. During this time the LED will be blinking. Do not power down the Tablo until the LED is solid again.
This hotfix update is to correct a few small bugs we’ve discovered recently, the most critical of which can cause a subset of Tablo OTA DVRs to go offline should a server outage occur at Tablo HQ.
For tips and tricks on successful firmware updates head over to the Knowledge Base.
Have trouble connecting to your Tablo after the update? Use these troubleshooting tips.
Otherwise, if you have any feedback or questions about this release, please post them below.
If you need support assistance, place a ticket and we’ll be in touch soon.
My sentiments exactly!
One day I have all my cover art and the next day 30-40% of it disappears!!
This just occurred within the last two days.
This new update still isn’t addressing this problem!
It’s getting beyond ridiculous already that this problem is taking forever (or longer) to resolve!
The same exact provider supplies the cover art to numerous other outlets and there are no problems whatsoever elsewhere (and no need for perpetual excuses, either)!
Yet, whenever I’ve called (after waiting far too long to connect), it’s always the same nonsense.
“It’s the provider and we’re working on it”.
They always pass the buck and there seems to be only two speeds when it comes to “working in it”. Slow and stop!
To be more specific, I’m referring to the cover art that’s supposed to be provided for recorded shows. I thought that the problem was resolved (finally) and then after the next overnight connection, a substantial amount of my cover art was replaced with only titles!
This continues to be neglected (among other problems that remain on the “back burner” indefinitely)!
How much longer should it take to truly resolve this? Should it be in terms of years??
What made you think this firmware release has anything to do with the cover art situation? It’s to address a very specific bug and has nothing at all to do with the cover art situation.
2.2.36 had the fix for “Fix for cover art aspect ratio issue”
That is a different problem then the disappearing cover art. That seems to come and go. But since I haven’t been recording tons of different shows I don’t see it very often anymore.
@VideoWizard How soon after initiating the upgrade did you try to connect? Sometimes if you try too soon and the Tablo is still processing or rebooting it won’t be available.
It’s been several days. How long should I have to wait? :-). I was on vacation in central US. Box located in one of my houses in Southern California. I have since returned home to Northern California and still can’t access. I guess I’ll have to wait until I can return to SoCal in a couple of weeks to fix it.
Does this correct the No Storage Found bug I’ve been having since the last update? Tablo just craps out and doesn’t recognize the installed HD. I have to reboot the Tablo when it fails, whats worse is I work on the road alot so when I’m on the road I miss weeks of my shows. I have removed the HD and ran a battery of test software on it from both my personal laptop and my work laptop, HD is 100% working.
This should be resolved over the next month or so based on the changes we implemented in .36.
As mentioned previously, brand new programs should all have the correct aspect ratio images as they premiere.
As guide data for previously aired programs returning this fall becomes available, images will also be updated with the correct aspect ratios.
Programs not airing again until later next year (like This Is Us) will be updated soon as the Tablo looks for ‘new’ images for each series which happens every 100 days.
Each TV series is on a different ‘100 day’ schedule depending on when your Tablo was first set up, and when the series began airing.
I’ve been having the same issue with failed recordings, ho HD found. Support is of no help. They told me twice in the last year that my HD was bad. I replaced it and still have problems. Both HDs test perfect. I am seriously looking for other options for OTA DVR.
In just the last 2 weeks the following have occurred:
On my Samsung TV, the app refused to connect but on my NVIDIA Shield equipped TV it was fine.
I rebooted the Tablo and all SEEMED fine.
On both the Samsung/NVIDIA Shield, on the local network news, the small progress display images were not available even 2 hours after the show.
I rebooted the Tablo and that fixed it for a day.
Now the Samsung TV does not connect again but the NVIDIA shield works but some shows are not recorded and the progress display images are gone again.
For whatever it’s worth I’ve read the various complaints and issues.
I can only assume that many are local network and/or streaming device issues because the performance of my Tablo Quad has been absolutely flawless. The only times I have encountered any problems it has been network problems that have been easily fixed with a router, modem and device reboot which I do as a routine network maintenance practice.
If some of the things mentioned here on my network happened and i didn’t notice them, they seem to have resolved themselves during channel search updates and saves which I do often as a simple practice to keep network appliances (security system, streaming devices, energy monitoring devices, router, modem, etc.) in general supplied with current data and to clear trash from caches.
Rebooting devices and clearing caches is always a good first step to troubleshooting any network problem and keeping a network clean and free of resource conflicts.
Bottom line is that I have noticed none of the issues reported here (some I may not care about and haven’t noticed if they had nothing to do with reception of programing) and the overall performance of my Tablo Quad to view television programs and the information regarding programming has been simply outstanding.
Hope this advice helps some of these problems go away
I just updated both of my units (they were on the beta releases), and both after the reboot indicated “no storage”. I had to remove power from both units & hard drives and reboot them to get the storage back. Everything is working now (no detectable issues).
