NEW - Tablo Firmware Release 2.2.28
I just updated my Tablo box from 2.2.24 to 2.2.28. Now I am back to having a TOTALLY unusable Tablo Connect Live TV connection. Just like with 2.2.26, the Live TV program runs for 15 seconds and then buffers for ~10 seconds, etc…
Why are you guys incapable of fixing and test this stuff???
How do I roll back my Tablo to 2.2.24?
There are plenty of us running 2.2.28 with no issue, in fact some of us helped test it.
Maybe open another ticket with support so they can try to gather specifics and help you rather than name calling.
I’m sorry, I don’t know what that means. Is that the non-“Preview” version of the Firestick App? If I don’t hear from Tablo Support in a couple of days, I’ll try to figure out what that means.
I’m interested to know if the Preview version of the Fire stick application just doesn’t have support for upgrading (i.e. is deficient in functionality / software shortcoming), or if there is actually something wrong with my Quad, and/or account. If either of the latter two scenarios, I don’t really want to mess with upgrading the firmware until support has looked into it and given a green light.
Thanks.
By web interface I mean open the Chrome browser on your home PC and go to my.tablotv.com
On any/all app or device?
good question !
Chromium on Linux : Broke
Firefox on Linux : Works
Yup, and I would have thought just the opposite…
You forgot the magnifying glass in the forum :poop:
Linux itself is not an OS
I know on Chrome on Linux I had to clear all the app data (the SQL db manged by Tablo) and have it do the full resync, etc… Otherwise, it was “confused”.
SInce I did the update, I’ve had difficulties connecting to my Tablo. Anyone else experiencing this? I’m connected via WiFi. Both on my PC, or Roku. Sometimes a simple reboot fixes it but today I had to do a power off/on before it would find the unit.
I turn off the WiFi overnight so I need to reconnect in the morning. Have not had an issue until the upgrade.
When I listen to live TV, it errors out with a sync error. It hasn’t happened yet on a recording but 2.2.28 has only been running for 2 days. I can reconnect with no problem but then I get a sync error after about 20 minutes.
I have having disconnect issues also, and my roku,PC abd tablet cannot find the Tablo after upgrading, it somethings works after a reboot, worked for a while when I switched from ethernet wireless, but no more. I am going to try and factory reset and see if that helps but will lose all my recordings. It has worked great for the past 3yrs until now.
What exactly does the error message say?
If anyone else is having connectivity issues after updating, there should be no need for a factory reset.
Instead, please follow these troubleshooting steps:
Not sure what’s happening in your case as most folks leave their WiFi on overnight.
Is it possible to connect via Ethernet for a couple of days to see if your experience changes? If not, we could try to see if there’s something in your Tablo’s logs pointing to what you’re seeing.
Me too, my.tablotc.com cannot find the Tablo and asks to rescan. If reboot the Tablo it is fine for awhile. Interesting, if I leave the browser open on Tablo (assuming it found it) it will work. If I close the browser it will not find it anymore. have tried a couple of different computers. Definitely an issue only after upgrading to 2.2.28
Not really … my router is down a floor in my bedroom (that’s why I turn it off overnight). The
antenna comes in on the 3rd floor which is where the TV, Roku etc. are. I don’t have a cable that long. btw … It’s been fine for the past few days. So far powering off the Tablo and turning it back on and resyncing has fixed it.
I may try that eventually, but very frustrating that the update may force people to "upgrade’ if the units are bricked. Hopefully, the reset via power cord will work for me in the morning and I did not lose any shows from recording.
[quote=“ajdugasjr, post:97, topic:22819”]
but very frustrating that the update may force people to "upgradstrong texstrong textte’ if the units are bricked.
[/quot]
You believe this is a conspiracy? To brick units, forcing users to upgrade…
after upgrading the firmware tonight, the Tablo will not connect to my home network. I use a wired connection and it just will not communicate with my router. For the last 3 months, my Tablo was 100% awesome and never dropped connection or buffered. Tonight after the update, it started with buffering issues and then transitioned to network connectivity. Very frustrating.
Now I’m bricked. Did update over and hour later nothing still blinking blue. Great
@ghaydu I’m sure the situation isn’t quite that dire. Drop a note to support and we’ll get you fixed up: www.tablotv.com/ask-tablo/
