As promised, now that 2.2.10 is out the door, the cavalcade of announcements has begun today with the launch of our Add-On for Kodi media player software.
If you’re already running Kodi on some of your devices, or if you have a ‘generic’ Android box that doesn’t support our native Android TV app, this Add-On is for you.
The look and feel of the Add-On is very similar to our existing Roku channel:
Links to the official repository for users of Kodi Jarvis and to a zip file for users of earlier versions (including Isengard) can be found with the rest of our apps at www.TabloTV.com/apps
If you have any feedback, let us know below!
If you’d like to tinker with the Add-On and you’re not already a member of our developer program, drop us a note at info@tablotv.com.
Running the Tablo Kodi app on my Apple TV 4…is there a way to stop the Apple TV screensaver kicking in every 5-10 minutes or so? Other than that seems to run well, can pause and skip forward.
Figured out a work-around…in Apple Screensaver settings set the setting for running the screensaver while music playing to “OFF”.
Yes sorry i am going to start working on a rewrite once my vacation and travel for work slows down mid july … I have looked at the code and believe it wont take long once i get a clear moment. Would do it on the plane rides but kinda hard to test over gogo lol
I’m getting a Raspberry Pi to fool around with and intend to put Kodi on it. What OS do you use and did you get a specific Kodi package to install? Thanks.
Oh BTW can Kodi on a Raspberry be used with a cellphone as a remote?
