@Davidvr
@Jestep
I deleted the Tablo.bundle folder in the Plex plug-ins folder when I reinstalled and replaced it with a new folder. That was over an hour ago. It seems to be updating now.
@Jestep that seem to reset it when I access Plex through the AppleTV when I access it through the Mac it shows the old artwork. Hum
That’s great news! I have been racking my brain trying to figure out what it could be
The Tablo app for the iPad is great, air-playing through the AppleTV works nicely, but I’m glad to have Plex on the Apple TV now. I can play recorded tv and watch live TV without using airplay.
In Windows 7/8,
Thanks for posting those directions. Synch does not work due to bugs in plex outside of our control
@Davidvr, ok it happened again. Had to stop Plex Server, delete the same dir again, restart plex server. Clear Browser cache as it still showed the old shows. Then it showed the correct shows… Can’t tell what is happening, is it some caching that is set someplace, maybe needs to be set to a shorter time frame? Although, the other day it worked every half hour correctly , but I only checked for a few hours or so
@Jestop Can you download the build I just committed and give it a try? I found a plex setting that might have caused the live tv screen to not reload (also this build has a view new features, mainly you can now view scheduled recordings)
@Davidvr, still shows as .96 did the version not get updated? I know it is newer because I also see the About your Tablo…
"This channel is not responding."
I get “This channel is not responding.” on scheduled recordings and no change in Live TV
Yea, this morning I had to delete the data again to get live tv to update again/
@Jestep @HarryR I think I found the issue with scheduled recordings and I’ll update it later tonight with a fix
Doesn’t work for me on a Linux based PMS.
…from the log…
2014-07-14 21:30:19,425 (7f077a6ab700) : INFO (datakit:24) - Resetting the dictionary
2014-07-14 21:30:19,426 (7f077a6ab700) : INFO (datakit:118) - No default dictionary file
2014-07-14 21:30:19,426 (7f077a6ab700) : INFO (init:941) - ***TabloTV: cleartablodata: 'Clear appears to have worked’
2014-07-14 21:30:19,428 (7f077a6ab700) : DEBUG (networking:172) - Requesting 'http://192.168.1.73:18080/plex/rec_ids’
2014-07-14 21:30:19,431 (7f077a6ab700) : CRITICAL (core:613) - Exception starting plug-in (most recent call last):
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/core.py”, line 606, in start
self.sandbox.execute(self.init_code)
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/sandbox.py”, line 256, in execute
exec(code) in self.environment
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Tablo.bundle/Contents/Code/init.py”, line 988, in
loadData(Dict)
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Tablo.bundle/Contents/Services/Shared Code/tablohelpers.pys”, line 155, in loadData
episodelistids = JSON.ObjectFromURL(‘http://’ + ipaddress + ‘:18080/plex/rec_ids’, values=None, headers={}, cacheTime=60)
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py”, line 145, in ObjectFromURL
method=method,
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/networkkit.py”, line 67, in _http_request
req = self._core.networking.http_request(url, *args, **kwargs)
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py”, line 376, in http_request
return HTTPRequest(self._core, url, data, h, url_cache, encoding, errors, timeout, immediate, sleep, opener, follow_redirects, method)
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py”, line 147, in init
self.load()
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py”, line 187, in load
f = self._opener.open(req, timeout=self._timeout)
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py”, line 438, in open
response = self._open(req, data)
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py”, line 456, in _open
‘_open’, req)
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py”, line 416, in _call_chain
result = func(*args)
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py”, line 1217, in http_open
return self.do_open(httplib.HTTPConnection, req)
File “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py”, line 1192, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 111] Connection refused>
