@Davidvr - I fixed the transcoding issue with my Sony players. It looks like it was one of the CodecProfile VideoCodec limitations causing the stream to be transcoded. Once I removed the limitations, the stream flowed smoothly and my server relaxed.
@MikeNE - I saw your dilemma, and though I don’t have an LG MediaLink TV, I had to overcome something similar (vendor abandons support for older devices), so I felt your pain.
@chuckc - thanks. I actually bought Playz a while back. It works fine for my media, but doesn’t support channels…so the Tablo doesn’t show up. Per @Davidvr’s suggestion, I actually got Tablo to work through the TV’s built in browser…but navigating is a pain. I also can’t figure out how to shut off the mouse pointer while watching.
At this point, I think the only thing I’m going to be able to do is wait for the pay version of the official Plex app.
All in all, still a lot of progress for a few days…
Mike
don't know if this is related to the problems mentioned above, but recently I've had problems with all of my recordings older than about a week ago. Whenever i try to access them, i get the "M3U8: crossdomain access denied" error. They show up fine on tablo. Thanks for putting this channel together, its been great up until this point.
I’m running into the same M3U8 error when I access Tablo via Plex outside of my home network.
@snzkickin the m3u8 error is beyond my control (its a problem with plex itself) , but I think if you disable direct stream and direct play it will work.
@Davidvr Thanks for the reply. I should have said in my previous post that I disabled those two options without any success.
@Davidvr, not sure if anyone has mentioned this one, but on my amazon stick plex will not play anything. Just gives me a generic unidentified error in the UI
@Davidvr or anyone else… what is the solution to this issue? API Could Not Locate a Tablo on your network
@Jestep here’s what I get… {“success”: false, “error”: {“message”: “None found”, “code”: “80”}}
@Monte that’s it?
@Jestep - how does running that script help with Plex? Just confirm the Tablo has a valid IP on network?
@7up returns data about all the Tablos from TabloTV
I get valid return from script. Will have to dig deeper into why original Plex plug-in works fine but latest beta is problematic.
@Jestep… Finally got the thing working. Here’s what the script returns now…
<pre style="word-wrap: break-word; white-space: pre-wrap;">I'm assuming that's normal. :)
How do I use the beta? Does it support FF through recorded shows? Will it pick up where I left off? This is just all such new technology to me, but it's fun! ```Thanks, ```Monte ```
@Monte first, probably don’t want to post all of that as it includes your MAC address
@Monte or @Jetstep or anyone else: I’m having the same problem Monte reported here.
- When I try to access the Tablo channel with my Plex, I get: the message “API could not locate a tablo on your network”
- When I enter the url https://api.tablotv.com/assocserver/getipinfo/ in my browser I get
I have plex server installed on a Windows 8.1 machine with ethernet access and working well for all other purposes. I have Tablo installed on my ethernet LAN and working well with iOS, Windows, and Android devices.
I have the Tablo channel installed in Plex, but the API can’t see the Tablo. I’ve tried overriding the settings with the Tablo’s IP address, but I get the same result.
I would appreciate any help, thanks.
Vanessa
If you enter that URL in your browser and get that message then as far as Tablo is concerned you have no Tablo on your network. That should return a lot of info about the Tablos coming from your network.
Hi @Jetstep
OK, we managed to track down the network conflict that was causing that problem. It’s now working great!
Thanks
Vanessa
Did you ever figure this out? I’m having the same problem and (naturally) the Plex forum is down.
