As i SAID- YOUR SOFTWARE ID ALPHA. $33 and i can record and plug in a Pc or Mac and get the file.
GLOBAL RECORD once may have been nice 35 years ago, but i think my first VCR had more options than this.
Repeating a Program Record, daily, weekly, etc, SHOULD NOT BE A MAJOR ISSUE, just a CHECK BOX.
I thought i was buying a PREMIUM PRODUCT… not one that a Tuner 1/10th the price does a better job.
We buy technology to make work EASIER, not to MAKE MORE WORK. You do not think through your technology to cover the proper options and BACIC NEEDS of the user. And Referring me to your manual does not correct a dysfunctional product and software.
Keep justifying yourselves, but read about Adam Osborne, or Sony Betamax… SHORT LIVES, even with such great potential. Your app on Fire TV BOX resets so often, and outside of a PC that is the most powerful device to connect to a TV.
I can write a book or 2 on all i have been through.
BOTTOM LINE YOU NEED TO MAKE IT FUNCTIONAL, and so that a person can set it and forget it, and not have to daily maintain the schedule, because you do not allow simple function, Record this Program DAILY or WEEKLY at this time, or later, should it change from a normal programming time, as sometime 60 minutes comes on at 6:30 or 7:00 and not 6pm. This i NOT ROCKET SCIENCE, go to WWW.tvguide.com and that i WHAT WE WANT, and click it and say record once, weekly, daily, etc. SIMPLE.
