Coax connector on Tablo is loose
I have had the Tablo about 4 months. The Coax connector on the Tablo is loose. Will this affect my reception? I used to get good reception, now I am missing channels and getting a lot of buffering.
I enjoyed it before the buffering and missing channels. Can I get this fixed thru Tablo since there is a 12 month warranty on it?
most likely YES
fixed,no replacement YES (replacement = refurbished)
You’ll have to go though tablo support… or
https://support.tablotv.com/hc/en-us/requests/new
It is very uncommon, there has been a reports of this…
My TabloTV Coax connector is broken!
Coax connector spinning in unit
