Had my 4-tuner Tablo since summer 2014 and the AC adapter finally died. Solid blue light on the Tablo and no response. Hard drive clicking with no power LED. Ordered a replacement adapter from Tablo and we’re back in action. Missed out on a week of shows but at least my Tablo is alive.
Just wanted to provide another data point and symptoms in case others experience a similar failure.
My very old Tablo 2-tuner adapter seems ok for now. Just curious, would be nice to know if people with bad adapters were protected by a UPS or not. Power sags can be really evil.
Just wanted to provide another option for a Tablo power supply. If you visit your local thrift store (Salvation Army, St. Vincent DePaul, etc.) you will likely find a bin of miscellaneous AC adapters. Look for one with a 12volt output and 1.5 amps or so. These usually have the right size barrel to fit the Tablo. Most of the time these adapters are $.50 or so. Even if you don’t trust it for the long term , at least you would have power (or be able to test for a bad power supply) until you can get an “official” replacement. It is definitely worth a try.
I understand what you are saying. I have 2 of the 2-tuner Table units. Both have the original power supplies made by Adapter Tech. Interestingly enough, one has a 2 amp power supply, the other has a 1 amp power supply, but both have worked flawlessly for a couple of years or more. I do have a small USB cooling fan that blows on both units continuously, maybe that helps.
