Will Tablo work with my 75" LG Smart TV
I would like to cut the cord, but want to know if I will be able to watch on my LG Smart TV OS 05.30.85
tablotv.com has amazingly useful search/support:
From How It Works - try Tablo Apps & Compatible Devices Scroll down to Tablo Compatible Smart TVs select LG.
Select LG Smart TVs running webOS 3.0+ operating systems have a native Tablo app. Please check your TV for compatibility.
Then that link give you more insight for confirmation.
Try support.tablotv.com and put LG TV in the search box, maybe start here -
https://support.tablotv.com/hc/en-us/search/click?data=BAh7CjoHaWRsKwhMsDLUUwA6CXR5cGVJIgxhcnRpY2xlBjoGRVQ6CHVybEkicGh0dHBzOi8vc3VwcG9ydC50YWJsb3R2LmNvbS9oYy9lbi11cy9hcnRpY2xlcy8zNjAwNDIzNzcyOTItV2hhdC1TbWFydC1UVi1tb2RlbHMtb3ItYnJhbmRzLWhhdmUtYS1UYWJsby1hcHAtBjsHVDoOc2VhcmNoX2lkSSIpZjA2NjJhZjQtODA4MC00YWY1LTkyMTMtYzc4YjZhOGE1MDkxBjsHRjoJcmFua2kH--4049766015ec300d7287472b30493da4951f8736
Select LG Smart TVs running LG webOS 3.0+
However, LG and Samsung Smart TVs both use proprietary app stores which offer a fractured and limited app selection. Tablo cannot guarantee that a native app will be available on those platforms.
Kind of makes 75" LG Smart TV waay too vague.
They strongly suggest -
If you’re planning to rely on your Smart TV for your primary Tablo viewing experience, please search the app store on your television before making your Tablo purchase to avoid disappointment.
There you may find some way more useful info -
(I think this is *dated")
On every tablotv.com page there’s a search box, just put in LG TV, you’ll get bunches from all sources.
Here’s one you don’t want to miss -
