OK thank you for follow up can clearing it up cjox. Wishful thinking in my part, It is the same with other DVR’s. It is a broadcaster thing (copywrite).
Just as a side note, I have an Ematic AT103B I play with in the spare bedroom on an older Sony (not smart TV). It has one of the two Roku 4k sticks now.
The Ematic is just an oddity but for what it is and cost it works. I recall 4 yrs ago I paid $34, You can get them today for that or less. It is barebones but records to a HDD) in a *MTS easily uploaded to a PC and played by media players. I am using an old 500mb HDD I paid $5 for. HDD format is FAT. I need to try flash drive sticks. No WiFi needed or wanted. It gets a schedule encoded in the stations signal. You can get 12 to 24 hours of schedule I recall. It even gives you detailed show description (with button pushing). It has a nerd interface, text not graphical, not for people who can’t set a digital clock in their microwave.
To record with the Ematic you can select from the station sent schedule or manually change the channel, start stop time and date, once/daily/weekly. The file names are crude by todays ICON thumbnail graphical standard. It is text list, with channel ID + date + start time. It is a one tuner deal… So you can only record and/or watch one station. However for $23 + $5 HDD it works… It is crude and requires more user button pushing, menus, manual programing… The BONUS, files are 100% not encrypted or in format that can’t be played directly be media player on phone or computer.
There are a handful of weird things. It can’t record one show past midnight. If the show goes from 11:05AM to 12:05AM it will not accept it. There could be a workaround and/or I am doing something wrong. Software updates is via USB port. You go into settings and say update and it looks at USB for file. Since my unit is older I thought about trying to update the software. As far as I know it is not supported. I looked and sent email… It is likely some Chinese factory that still pumps these out and has zero support and likely software is not available. They have been out for 10 to 13 yrs and still sold new from $28 to $38, Walmart has a $23 sale. So they have a following.
I AM NOT RECOMMENDING EMATIC… Only mention in relationship to having un-encrypted files you can play on PC media players away from DVR.
Computer based DVR with a Hauppauge TV tuner and software I built up in the late 2000’s (about the time digital TV came out) also recorded in open format not Linux or encrypted… but the software, schedule was advanced. The TV schedule was free and the interface with graphical. You still needed to open a program and to see the shows go to a folder and select program. NERD quality user interface, software settings, etc. Hey it’s a hobby.
I have to admit the DVR’s from Tablo, TiVo and Channel Master DVR’s (now out of DVR business) and others, with all the streaming channels, advanced schedule features, graphical interface are very nice, but restrictive. Also they are small compact units, that don’t require you keep your PC on all the time.
NOT RECOMMENDING THE EMATIC AT103B. It is not well supported and in many ways “flaky” like a digital version of a 1980’s tape VCR. However that is part of it’s charm. I am going to try a Flash Drive stick in the USB port. I think you can swap drives or memory stick without worry? Don’t know have only used the one drive. Many DVR’s are tied to that one storage device and can not be swapped unless you format the new storage. I have been told once you do this you can not reinstall the old drive without reformatting (erasing the data).
If EMATIC records to flash drive it allows me to plug into a laptop USB to watch a show while traveling, off the web, great. If not I can take shows of HDD and then transfer the MTS files to flash drive via PC, if I don’t want to carry around the compact HDD.
I know other DVR’s allow you to stream content from your DVR’s storage away from home Via Internet. May be that is what I need? I had a SLING 8 years ago, I used with cable company DVR. That was really flaky but worked. You had IR repeaters to remote control the DVR. SLING discontinued this service, but the idea of watching recorded shows on any media player (cell phone, laptop, PC) off the internet (in the back in an airplane) is something I would use.
The Tablo and Channel Master DVR are what I am using. But the Ematic experiment continues. It is a hobby not a way of life. I will say the Tablo is warming up to me. I solved all my teething pains with the Tablo. If it lasts (does not die like my first Channel Master did after 4 yrs) great. Like I said if you have encoded shows on a DVR that goes bye bye you also lose the data (unless you use Linux and some conversion utility).
In this DIGITAL world companies can spy and control what we do and how we use their products. Tesla can shut features off on your car remotely. Samsung can shut your phone off it is was bought on grey market (a phone used in one country that was marketed to another country). There is good about technology and bad. Would I go back to VCR? No.
