I promised I searched for this one. Apologies if it is obvious.
With Tablo and a Roku… can I watch a program while it is recording? This is a very common use case with our TiVos… we typically start watching an hour-long program 20 minutes after it begins so we can skip the commercials and still stop watching on its regular schedule.
Does Tablo support that kind of time shifting?
@cedarrapidsboy - Yes - you can watch a recording in progress on Roku. It appears in the ‘Recordings’ section after 30 seconds.
And PS - awesome avatar :)
Got an answer to this question:
Yep! You can start watching a recording after it’s been in progress for 30 seconds. All you need to do is navigate to the Recordings menu and it will show up there.
I hope this helps! Let me know if you have any other questions.
@cedarrapidsboy - Yes - you can watch a recording in progress on Roku. It appears in the 'Recordings' section after 30 seconds.
Thanks. As you can see, also got an answer via email support. GREAT RESPONSE TIME!
