I’m unable to connect to my tablo, this started since the last software upgrade (firmware 2.1.30). I have reset the Tablo using the reset button and have also unplugged the tablo for about 15 minutes before plugging back in. I’ve tried the Roku and the Web client and neither will connect. The Roku, comes back with a message about no Tablos on the network and the Web client keeps trying to connect but never successful. I was one of the customers having the “weak signal” issue and was excited about the new firmware release. I was able to reconnect to the Tablo, when having the “weak signal” issue, but with the new firmware I can’t even get a reset to work. I can see the Tablo in my routers client list and can connect to it via the browser and get the message “Nuvyyo Tablo Server”.
Any one having this same issue and if so, were you able to fix and what did you do to fix?/
I would hold off on a factory reset at least until tablo can take a look by a remote session. Submit a support ticket with them and they’ll likely look at it tomorrow.
