I’m having issues with my Western Digital MyPassport Ultra and want to upgrade to the very best possible unit. I’m wondering if any of the SSD units have been tested and confirmed? Or is there a standard drive that gives good (fast) response?
If it matters, Seagate (often found play catch-up tech wise) is doing a RAID 0 across 2 x 2TB drives. Could be a pro, could be a con depending on perspective.
Since I replaced my Seagate BackupPlus 1TB drive with this drive about 2 weeks ago, the Tablo has been working flawlessly.
Before getting the STEB5000100, I was having constant issues with the Tablo. I reformatted my BackupPlus multiple times, but problems persisted. I was ready to give up on the Tablo, but decided to try this drive first.
So far so good.
I guess my contribution here is:
Seagate BackupPlus 1TB = BAD
Seagate Expansion 5TB = GOOD (so far, 2 weeks)
I have upgraded to the 5TB Backup Plus Desktop a few days ago and it has been rock solid so far. The unit that it replaced was also a Backup Plus Desktop (4TB) which I purchased several years ago, but the case looked completely different than the new one.
@TabloTV, I understand you have verified compatibility of the Seagate 8TB drive, but have you let it run for extended period of time to make sure there is no performance issue at all? I’m thinking about getting that drive when I see good sale on it, but I want to make sure it won’t have any problem with Tablo in the long run. Can anybody share their experience of using that 8TB?
@faganm24 - We haven’t, but generally what you want to be looking for now with Tablo drives are ones that are not prone to disconnects. If you do a Google search on the drive name + disconnect and there’s 10 pages of results, avoid it like the plague.
@kamy2015 - We have been running the 8 TB for a long while now and recording multiple streams all the time and it’s performed well.
Before I buy one of the recommended Seagate drives (Expansion 3TB or Backup Plus 3TB) I wanted to know if anyone is successfully using an external SSD drive with Tablo?
