Used Tablo in the AM Sunday (Jan 11th). Recorded a news show. Went to re-use and Tablo was offline. I went to unplug (wait 30 secs) and replug. I did not get a blue light. I tried a factory reset. I still have no blue light. I contacted Tablo as it is only 11 months. Any thoughts to try?
If you haven’t already, test the power supply. They go bad sometimes. If the the power supply is working, but the unit is still dead it likely needs to be replaced.
Phone Tablo support. You will get a faster response on the phone: 844-822-5688. They are really good about replacing defective units under warranty (and even a short time out of warranty).
Thank you. I appreciate the feedback. I called the service department.
