When I rip, the resulting file is incomplete. If I view the recording on the Tablo app, it’s a full 30 minutes. But the ripped show can be 8 minutes or 22 minutes …. But only sometimes is the show complete! Any ideas??
Nilex
January 5, 2023, 5:03pm
#2
You probably want to post in this thread for visibility…
Since you have ripped some shows manually, I suggest deleting the log file, not doing anything manually, then allowing some time for the background process to kick in. That way it’ll be easier to see what’s going on.
Alternatively, open the program, wait a while, then scroll all the way to the bottom of the log file. That’ll get you the most recent activity.
However, you might go ahead and do the first step of troubleshooting if you haven’t already…
As always, enable logging, try a rip, disable logging and look for an error at the bottom of the log file.
If the problem isn’t obvious, let me know what the log says.
