Tablo Ripper was putting my movies and tv shows into separate folders and now it’s not. Is that a setting in configuration? I turned off the date and channel settings and I don’t know what the megadata setting is for. I have the plex setting on.
We strongly recommend separating movie and television content into separate main directories.
I think it’s probably a Tablo Ripper setting [plex] based on plex naming conventions
If you believe something is flubbed up, turn on logging and post in the Tablo Ripper topic
Do if you have a question or suggestion, post it here because I’ll get a notification and will try to respond
