If I purchase a new Quad ATSC 3.0 Tablo, can I continue to use my current Tablo on my wifi network to stream recordings? Also, would I have to purchase an additional guide subscription or would both Tablos be able to use the one guid subscription? What I would do is put the new Tablo on my living room TV and still rely on my Roku devices to stream recordings from my current Tablo over wifi like I am doing now.
IF your Tablo subscription account was created after those policy changes, each Tablo on your account will require its own subscription if you want to have subscription features on both.
You can still watch live TV and set manual recordings without one.
Plus, the Tablo ATSC 3.0 QUAD HDMI is an officially licensed Dolby AC4 device and therefore can only provide playback of ATSC 3.0 content on officially licensed devices. Other companies as mentioned may have chosen an unlicensed approach.
I have the HDHomerun Flex 4K, and while it does stream video, the audio doesnât work on ATSC 3.0 channels on my Roku devices. It does work most of the time on my FireTV devices (there are times when I am kicked back to the main menu when watching ATSC 3.0 channels). The XBox One and Windows PC work virtually all the time with the ATSC 3.0 channels.
The frustrating part of ownership is this - support fixes a problem today. Then the broadcaster makes a few changes, and guess what? Something breaks. Support takes a few days to fix it. Then it restarts again.
To be honest, it is nothing more than a âtoyâ right now. 100% of my recordings (stuff I really want to watch) are on my Tablo devices - because it works 99.9% of the time (nothing is perfect). So, reality is I spent $200 on a toy, that is neat and fun to play with, but I donât rely on it for watching most of the timeâŚ
SiliconDust (maker of the HDHomerun) has always been one of the âfirst releaseâ companies, and they have worked hard to make things work, and eventually it gets there. If you want something today, be prepared for bumps in the road. It may be 1-2 years of ownership before it works close to perfectly.
Tablo makes sure it works virtually all the time before it is released, and there are very few bugs.
Yes and it would also have to support any DRM or HTML5 features that are also required for the new standard.
Since so much about ATSC 3.0 is still âin progressâ weâll be focusing on a TV-connected experience so we can make sure that all of the features of NextGen TV work as they should.
Just thought of another question. My main TV is on the opposite side of the house from my internet router/access point. It is not possible to connect a TV connected Tablo to the internet wired via ethernet. Will the new Tablo Quad be wifi capable to connect to my router for guide data?
Not at this time. Weâre trying to ensure that whatever we provide works equally on both ATSC 1.0 and 3.0 channels so thereâs no guessing for the end user.
