@Davidvr @theuser86, we are talking internal IPs right? Not external…
@Jestep, it will work with either internal or external addresses as long as the right port is forwarded from the external address
@Davidvr I assume single Tablo though if that is used?
@jestep yes it will only work with a single tablo , I want to support multiple units but it is almost a complete rewrite of the code
@Davidvr, wait, if I use the internal IP of my second tablo it should work right??? I thought that was the point of the override?
@Jestep Yes if you use the internal IP of the second tablo in the override it will work. What I was talking about is that I would like to rewrite the plugin to aggregate all of the shows from multiple tablo’s into a single view
@Davidvr ah yes that would be different, but totally cool
lol
I was talking external IPs as my Plex Media Server and Tablo are not on the same local network.
@theuser86 @jestep I just got word that the changes are merged, try closing plex then relaunching it. The build should be .992
Still 991 for me
So I tried updating manually and it just spun… Tried uninstalling, clearing the files, etc now installing only spins.
Uninstalled and installed. The VERSION file in the Contents folder now states “97ea592 (Thu Dec 11 22:21:44 UTC 2014)”. However, I cannot set the IP override unless the actual channels shows up under the Home screen in the Plex Media Server. The Tablo icon only shows up there when I have first connected to the Tablo. This is not possible as the Tablo is on another network. Kind of like the chicken and egg paradox.
@Davidvr interesting here:
@theuser86 If you hover your mouse over the tablo icon, you should see a gear that you can click on
@Davidvr Yep that gear icon is only available when the Tablo channel is shown under the Home screen or the Channels screen. It is not shown there but only under the Installed Plug-ins screen (you get there from the Channels screen by hitting Install Channels, More… and then Installed Plug-ins). Right now the Tablo icon is not shown under the Home screen or the Channels screen, but does show up under Installed Plug-ins.
@theuser86 I may have a workaround, I’m not sure why the channel isn’t showing but past the following into /Plug-in Support/Preferences/com.plexapp.plugins.tablo.xml
@Davidvr, any help would be appreciated. Just hangs there for a super long time, then it thinks it is installed but does not show up
@Jestep, shutdown plex, go to your plex application support folder and delete anything with Tablo in the name and then try installing it.
