Any idea when this will be available? LG Content Store currently shows Version 1.1.4 as the latest version. I’m on webOS 3.8.0-61106 (deadlocks2-dunggirl). Thanks!
“Play from beginning” during live recording is not working? Tried that on NBC Nightly News tonight- it started at the live point in the broadcast, not the beginning.
updated 26 June 19:
Not working? Recording “Good Morning America” today, while “start from beginning” pull-down option appears, recording still playback at current time.
Also, the app appears to take longer to load than the previous version, FWIW.
I’m seeing same issue. I see the new features but watching a recording in progress does not start at the beginning of the recording. The first time I tried watching a recording in progress, I started to go backwards to beginning and then Tablo shows a Player Error. I tried again and did not get the error when going backwards to the start.
Load time is slow but I can’t say if it’s slow than it was before.
My LG tv can no longer use the TABLO APP. It comes up and just has a blue screen. I loaded the app on my phone and its working fine. How can we go back to the old version? I assume this updated recently.
Same here- it doesn’t matter which screen you start from. The recording screen gives the pull down option to start from beginning, but it still starts from the live point.
The 25 second load time between starting the app and the “connecting” pinwheel screen appears is also annoying.
We’re investigating this behaviour now @JDW@tapokata, and we’re also looking into why some TVs are having issues launching the app @t_g_farrell. We’ll post an update as soon as we have news.
Quick update: we’ve pushed a small change to improve the app loading time. This remains version 1.7.4 - this will likely take a few hours to propagate in the LG App store. When you get a chance, let us know if you see the improvements on your end.
I deleted the prior version, and downloaded the “new” version. FWIW, this is still identified as version 1.1.4, last updated 10/25/2016 in the LG Content store, so that is not helpful.
The settings information on this version is showing as:
HTML Application 1.7.4 build 137 [201907031514],
so I am guessing this is the latest?
In any case…I am sad to report that there is no change in the loading time. It still takes 25 seconds between the launch and the start of the “connecting” pinwheel before the screen is populated.
