Hi, I’m new here. Everything was working ok until I rescanned my antenna. Now the new stations I found won’t fill the grids with program info. I am still in the 30 day trial. I did do the update button and even did a system reset. I am about to take this thing back to the store. It’s seems really buggy. Thanks for any advice.
It may be that those stations are a bit far away to be automatically included in your Tablo guide. Just make a list and submit it to Tablo support. Support will have the guide provider add them for you. It takes between 1 and 2 weeks but they will be added. I recieve a station that is 65 miles away, support got their guide info added for me.
Is this just only a select few channels? Or all of them?
If only a few, then likely the guide data for those channels are linked to your zip code. Contact Tablo Support directly via a suppport ticket to have them add the channels to your zip code.
Email support@tablotv.com and tell them channel number and network and zip code. Then wait a couple of weeks… You can watch by clicking channel number. You can do manual recordings.
It’s been reported/suggested - How difficult can it be and how long will it take - it may be difficult so it might take a long time ![]()
If your guide data is still missing, definitely send us a note and we’ll take a look.
