[I had to update this thing due to changes in my situation, and general screwups. Sorry
This is a weird one, and I’d love to hear not just solutions but explanations of what is going on.
- My setup consists of a Tablo Dual Lite plugged (via CAT5E) into a Linksys router that has been put into “bridge” mode. This “bridge” is connected, also via cable, to our main router, which in turn is connected to a cable modem.
- The Dual Lite is running version 2.2.40
- I don’t use the Tablo from outside my home, nor I have a subscription that would explain my tablo connecting to anything outside my network.
- I don’t have any storage attached to it, or use cloud storage of any kind
So… I’ve had the tablo for a few years now but until recently we had not started using it “for real”, since the reception was too crappy. I installed a much better antenna last week and reception is fine, but then the Tablo come up with one very strange problem: every day, and sometimes multiple times a day, all the devices in my house (two smart TVs, a couple of Rokus and even my computers) would lose connectivity with the Tablo. Only my phone (Android) could still access it. On other devices I get a message saying a Tablo cannot be found.
Here’s the kicker: when I check the settings on the Tablo app on my phone, it says that the server IP is 192.168.1.6 - which is NOT an IP assigned by my router (or any other device on my network, for that matter). My router is configured to assign IP addresses on the 192.168.0.X subnet only.
I changed the settings on my router to assign the Tablo a fixed IP address based on the MAC address reported on the app (and at the bottom of the device itself), but this thing kept connecting as 192.168.1.6.
After hours trying to figure out what was going on, I reset the Tablo to factory defaults, but the issue continued - same IP address
Finally, I tried to connect the Tablo via WiFi, but when I checked the app, it first told me it had connected to an external IP: 209.252.169.89, which seems to belong to an ISP in Iowa (I’m in Michigan). Not long after that it did connect to my network, but not to the IP I had reserved. Instead, it connected using DHCP, as 192.168.0.69 (according to the Tablo app)
HOWEVER… when I checked my router, the x.x.x.69 address shows as being used not by Nuvyyo, but by a device with a different MAC address, and named “Hui Zhou Gaoshengda Technology Co.,LTD”. I checked the app again and I confirmed it was using x.x.x.69
I reserved another IP address to this new MAC, and now the Tablo seems to be happily connected… to the first IP address I had reserved for it ![]()
I’m not claiming this fixed the issue just yet (it may fail again in a couple of hours), but at this point seems to be working. If this thing goes to another IP address, however, it may break the whole thing again.
I’m assuming the Tablo has different MAC addresses for the Wi-Fi and the Ethernet adapter, but I fail to understand why or how it:
- was getting connected to an IP that my router can’t assign
- showed me an IP address (under “Server Host”) from a different ISP, on a different state than mine
- now is back to the IP it should have used to begin with.
[Edit, 5 minutes later] The Tablo is, once again, connected to 192.168.1.6, and not accessible from any of my devices except my phone.
[Edit, 5 more minutes] The tablo is, once again, connected to the Iowa IP address. How on earth can my cellphone still communicate with it?
Any insight?
Thanks!
