My Android device keeps popping up the message “Tablo has stopped”. Which confuses me, because I have no idea why my Tablo app would be running.
I’ve installed the app on my device, but I’ve only rarely used it, I’m usually away from home and out of range of my local network when I’m seeing this happen.
Is the Tablo App configured to try to autosync, or something, periodically throughout the day? Something has to be trying to start it, and it’s not me.
Same here. I can make it always happen when I disconnect my headphones from the phone while using Plex. Guaranteed. And I get the message when I’ve not even started Tablo.
My device is a T-Mobile Note 5 running Android 5.1.1. I have hit the report button a few times on the crashes so the Android team should have some crash logs. The app version is 1.0.21 and there are no updates in the play store.
I also have a Samsung Tab S 10.5 running Android 5.0.2. It is not having the crashes.
I’m running a Samsung Galaxy Tab 4/Nook (Android 5.0.2)
My app is version 1.0.21. And I’d had the Tablo Video Player installed. I just started the app, and was told the separate video player is no longer required, and was prompted to uninstall it.
Based on some of the crash reports this may be an issue that has been fixed but not pushed yet. We’ll continue to check in on this so please keep us posted.
FYI… I’m getting the same error, and it happens every time I disconnect headphones (wired) and when I disconnect bluetooth (e.g. shut off my car and I get “Unfortunately Tablo has stopped” error). And like others have reported, this happens even when I haven’t been using the tablo app since my last reboot.
I can reproduce the error when using screen mirroring (Samsung S5 on 4.4.4) to mirror Sling TV to Roku 3 and then switching back to the Roku Sling TV app via the Roku remote. Every time: “Tablo TV has stopped” even though Tablo was not open at the time. I hope that makes sense.
@Max - That’s very likely. Unlike iOS where there’s a defined set of devices and a fairly small sandbox of iOS firmware, there’s SO much variation in Android devices that they can sometimes behave unexpectedly. We have a fairly decent amount of devices between our internal stash and the beta team but we don’t have every device/firmware permutation covered.
