I just this same message on my Fire TV. I just updated to the latest Tablo App this afternoon
xxx ccc xx cc
did you not finish ? because it looks like the next step would be x c
duplicate deleted
Just and FIY. I have a Samsung S7 edge and a Samsung SM-T700 tablet. I got my Tablo last month and when I first set everything up it all worked perfectly. I am streaming to a Chromcast dongle (I have two of the original older models) and I am pretty sure there have been no firmware updates on those. I started getting the âUnfortunately, Tablo has stoppedâ message about two weeks after having the Tablo. The first time I got the message I reset everything and uninstalled / reinstalled Tablo and the problem went away for a day. Then it came back.
I personally thing that the problem is not the Samsung devices or app but something to do with the Tablo / Chromecast streaming. Streaming continues even if I uninstall tablo on the Samsung device! It behaves as if there is an unreleased buffer or Tablo streaming mode is stuck. I also donât believe the problem is with Chromecast either because it streams normally otherwise. I would probably guess the problem isnât with other streaming devices such as Roku etc⌠because those users are complaining as well. Hope this helps narrow down the problem.
@rpopeszku - There is an issue with Chromecast at present. A fix is currently in testing and will be released soon.
Will this be a Tablo firmware update or a Tablo application update?
Rudy
@rpopeszku It will be an app update.
Any idea how much longer on it? Weeks or days? Also will it fix the problem where it wont let you skip ahead? Sorry just really want to switch to my Chromecast again.
@Monkey - Hard to tell. Everytime we think weâve got it licked, something else pops up. There has been a lot of fist shaking from our Android team but theyâre heads down and grinding through it.
Hey everyone!
This is what our Android team has been doing to the Chromecast code:
http://stream1.gifsoup.com/view/530748/stewie-kicking-ass-o.gif
Itâs been a tough, bloody slog but theyâve managed to beat it into submission.
An app update with the Chromecast fix is making its way through the interwebs as we speak.
Thanks for your patience as we worked this one out!
OMFG!!! Thank you Android TEAM!
EDIT: NVM it still sucks. It still can not fast forward and just starts at the beginning not where you are actually at in the stream. It does not crash the app though but still worthless.
Same thing happening here on my Nvidia Shield Android TV device HTML application 1.0.3 1 app now takes forever to load and every time even when Iâm not in the Tablo app keeps crashing I have two devices and it does the same on both Nvidia Shield devices
@Artemus Touch base with our support team. We should be able to find out whatâs causing this.
I have a Samsung 6 Edge+ (Android 6.0.1). I do not stream through Chromecast. I actually do not use the app very often at all. I am also getting the frequent messages that Tablo App has stopped working. I am reinstalling the app now. ( I think I already had the updated version, but am covering my bases). I suspect there is another issue at play besides the Chromecast issue that is coausing the frequent stoppages.
Mine stops whenever I go from WiFi to Cell coverage. Not sure why it is running all the time anyways. Just so it can waste my phone battery?
Iâm on a Galaxy S7 and have the notification pop up kind of randomly. Any info as to why this happens? The Tablo app isnât even running, or wasnât used and the message still pops up.
Any time I turn off my bluetooth device, âTablo App has stopped workingâ message pops up on me. In most of those cases, I have not run Tablo app in hours. So this message confuses me.
Some of earlier @TabloTV comments stated it would be an app update. The last update fixed a major Chromecast/Google Home upgrade glitch, but this issue with bluetooth persists.
Yeah, the constant Tablo has crashed, even when Iâm not using it, is somewhat annoying. Samsung S5 here.
Is this another Tablo - Samsung bug?
Also, while I am using Tablo, and put 2 fingers on the screen, it seems to crash Tablo (i.e. when you zoom). So itâs not just when Tablo is in the background.
