Installed the Tablo app on a Fire 8.9 HDX. Unfortunately, it more often crashes to the home screen when I try to play a recording than actually plays the recording.
Any idea what the timing (roughly) for getting this on the Fire TV? The Plex channel doesn’t work too well for me. I really want to like this device, it will do everything my wife want’s it to do(timeshifting, ability to start watching a recording before it’s finished), but I need a native app for Fire TV. I’m patient (when I have to be), just curious if we are talking weeks or if we’re looking into 2015. I know somethings are out of your hands. I don’t have a Roku and don’t want to buy one just to use this.
@jkline - The CEO would like us to do one, so that’s a good sign The groundwork is being laid now by our Android team as they work on stability and speed improvements.
I side loaded the Android app on my rooted Fire TV and it is working OK. The only problem is that it will only connect to Tablo via the WiFi interface…it won’t connect thru the Wired Ethernet connection; other than this, the Android app is working reasonably well. Hope we either get a real app for FireTV or fix the Android app so the Tablo can be connected using wired connection. I have another Android based media box with the Tablo Android app exhibiting the same problem…so this is definitely an Android app issue
Cool, any hint on whether we will be getting a refreshed Android app with Wired Connection capability or a real Fire TV app ? both would be nice
In the meantime, I will try see if I can bridge the WiFi and the Eth0 interface to see if it will workaround the wired connection issue on the Android app, will report back if successful
