Tablo App keeps randomly exiting back to Roku home screen
Have Roku 10.5.0 Build 4187 and Tablo Roku Channel Version 2.18.0
Tablo: If watching a channel, then use down arrow to change channel no issue. If watching a channel, then exit to guide to select a channel, go to Roku Home Screen
Tablo Alt: no issues with either of the above scenarios.
Thanks for the follow up. I saw the TabAlt but didn’t understand. I now know that it is a channel that can be downloaded on ROKU called Tablo ALT. When running this channel all of my problems went away. Thanks for the info. Thought I’d put this post here for the more challenged of us. Simply download the Tablo ALT channel via your ROKU website on computer. It will say it is not a known application and to proceed at your own caution, but get it anyway. It will show up on your ROKU and use it instead of normal Tablo channel.
My Ultra updated to software version 10.5.0 build 4191-46 just a few hours ago. I’m running the standard Tablo channel (2.18.0, not ALT).
The update seems to have fixed the thumbnail issue - I no longer have random missing/black panes :slightly_smiling_face:. The Roku player software now uses slightly larger fonts and displays more info while forwarding.
Will report back if issues arise, but looking very good.
My Streambar updated to build 4191-95. So far no issues on standard app. I have also not had the blank thumbnail issue, normally I see it at least once per day. Fingers crossed that it’s truly fixed.
Indeed. We’re cautiously optimistic at this point!
It looks like the exiting stopped. Haven’t experienced any problems over the last two days.
Hope others’ problems have disappeared, as well.
Roku has updated its software with minor builds at least twice since the ā€˜exit’ problem started.
Roku’s software version is now 10.5.0 build 4181-24.
Will report back if things change.
