Tablo Amazon Fire TV/Android TV App (4th Gen) Update (v. 1.6.0)
Hi folks -
An update is now available for Android TV and Amazon Fire TV apps for 4th generation Tablo devices.
This should provide a smoother experience for those experiencing crashes on the live TV grid.
Here’s what you can expect:
As always, if you have any questions or encounter problems, please post them below or touch base directly with support.
seems to be ok so far
Seems to be the same useless app as before. With march madness approaching it would be nice to go to the sports menu and find one list of all the NCAA mens basketball regardless of channel.
So far I can only find a useless list of "featured’ sports that contain empty entries for wnba, premier league soccer, poker, and NFL. and All Sports is a list of all sports. Nice
This release has fixed the two issues that I had with the program guide:
When scrolling up or down too fast, the Tablo app crashed back to the Amazon home page.
When scrolling too fast, the guide would say “Programing not available” on channels that just a few seconds ago had the correct info displayed.
Both of these issues have been fixed, and although still a bit slow, the guide navigation works better, especially when using the page-at-a-time buttons.
of course I have a ‘shows’ menu with an empty no icon list for both “live now” and "networks’. And just maybe if you provide a guide you should be able to filter it by channel.
@TabloTV thanks tablo
I’m sure that when i go to the “news” menu I should expect the networks and featured filter to be empty with no icon. I also find it hard to believe that morning news show includes "Kelly and Mark’ and no local news. And wow the evening new filter includes Jimmy Kimmel and Jimmy Fallon. Who would have thought.
sports tab and guide working fine here
@zippy
whats your device ?
It’s a 4K fire tv stick.
Are you saying that “Sports” menu Featured sports should contain NFL and WNBA
I also see that the “featured sports”/“all sports” filter instead of the 4 NCAA basketball games has no NCAA games. While the Live TV grid for the 20th has them. And they don’t appear in the “shows” menu under the proper network.
The gen 4 roku app is correct as are the legacy roku and fire tv stick app.
What happened to 1.4 and 1.5? I never received or was advised of these updates. I went from 1.3 to 1.6!
Hi @Lenlabnj ,
That is odd, we did release them:
Is it possible that your device didn’t have automatic updates enabled?
Correct I don’t have auto update enabled. However I DO get a notification that an update is available and asked if I want to update!
That is how I got notified about v1.6 Sunday.
I never ever got the other notifications.
We have 1.6.0 on our Fire TV and 1.6 on my Android phone. We’re checking out the Fire TV app and will report anything we find. We never use the Android app to watch anything. It’s merely a way for me to configure or update settings while my wife is watching on the Fire TV.
@zippy
if it works on your other devices then its probly your firestick firesticks are cheap underdeveloped devices :disappointed:
You mean a 4 core cortex A53 that can run 4K streams and runs the legacy app with no problem isn’t powerful enough for the gen 4 app.
power is not the issue its compatibility
Compatibility with what - itself. You do know that the original gen 4 fire tv stick app installed on the fire tv stick gen 1 and gen 2. Of course it didn’t run after a few releases due to an API incompatibility. At which point tablo blocked the installation of the app on those devices.
So if there is an incompatibility issue then tablo needs to block the app from installing like it did for the original fire tv sticks. Of course the gen 4 app is the only app that doesn’t run on the fire tv stick gen 2.
i use the same app you use and i dont have any of the problems you do. there are not to many android based devices that are made well most are cheaply made like the onn boxes that have got popular 2024 model is 20 buks the new pro model is 50 and you can bet that a 50 dollar box is not gona go through much development most firesticks are in the same boat quickly developed and poorly made i honestly think your issue is your device roku is better proly because thay have developed there own OS so so they dont have to wory about the app working on other devices our android app needs to work on a lot of devices
After 1.6.0 my Android TV (Sony Bravia) app is still crashing when I delete a recording. NOTE: the recording does get deleted, but then the app crashes me back to the Android TV home screen.
This problem does not occur if I delete a recording from the IOS or Roku Tablo apps, so it would seem its not the device, but rather the app for Android.
I tried clearing the cache, no joy. Also uninstalled the app, rebooted the TV, re-installed the app. This problem still occurs.
I have now opened this issue again with (had done so on a previous release - been an issue since at least 1.5.0)
NOTE: This is in regard to shows that have already been recorded. I am able to watch those recordings without issue. The crash only/always happens on delete in the Android TV app.
