A new Tablo firmware update is on the way for 4th generation Tablo devices. This just has a few small tweaks that are not user-facing that we wanted to get out before the holidays.
Dang. Was hoping that this would stop the FAST recordings from splitting so bad. The bug fixes and tweaks are likely for things I hadn’t noticed or experienced.
Nothing noticeable change to me either. No change in that the picture on many channels are still in the upper left quadrant. I don’t know if I’ll ever see a full picture again.
First time buyer, gen 4, i gotta b honest, i really doubt purchasing again, this is irresponsible beta shit at this point… and after scripps investment, sad, i expect better
Me too. My Tablo v4 is showing it is currently on Tablo Firmware 2.2.48, but is showing an update available that I can select which advises the update is for Tablo Firmware 2.2.48. Very strange.
I waited for a few hours on one because I knew it would screw up my recording. When I was between recordings, I updated the second one.
Now, both of my Tablos seem to be in constant buffering mode. Yay firmware update! It’s actually so annoying, I’ve gone in and reprogrammed things I know are airing again, just so I don’t run out of disk space before this is fixed.
(Yes, I’ve rebooted modem, router, and Tablos… but only once. It’s too hard to figure out when there’s a break between recordings. Especially when it affects FAST on TWO devices.)
I have multiple rokus and an android phone. I have only tried 1 roku and my android phone that both exhibit the same behaviour. I can try the other 3 rokus I have but what other information do you need?
I just got the 4 tuner gen4 the day before this firmware version was released, so I didn’t have many recordings before the update. So I do not know if this issue was introduced with the new FW or not. But scrolling through “All recordings” it keeps timing out. I have seen this on an android phone, the android app on a chrome book, and Nvidia shield.
After the timeout it re-displays the first few recordings. If you quickly scroll to the bottom you can see other recordings. But slowly scrolling down keeps timing out.
Tablo and Nvidia are both wired ethernet Phone and chrome book are wireless 5G
Sorry you’re still having trouble with your new Tablo.
Which of these do you think best explains what you mean by 1-2 seconds? 4th Gen LED
Have you been able to “see” your Tablo on any other device (Roku/Firestick/AndroidTV)? We you able to see a Disconnect option on any of your devices, including your phone?
Have you tried to force quit your phone’s Tablo app?
If it’s pulsating, we might be able to trick it into switching/adding your network – making sure your phone is on the same WiFi as your Tablo.
