Please read this before you respond - I’m specifically asking for people’s experiences dealing with support, I am NOT asking for suggestions on troubleshooting.
Both on here, and on reddit, i have read multiple posts regarding users having specific channels that have no guide information.
Users when submitting this to support get a response of
Please go through the following process to recommit your channels to your guide:
- Head to Settings > Guide > Channel Lineup
- Uncheck the problem channels
- Click Add to Guide.
- Enter “Channel Lineup” once more
- Re-scan
- Ensure that all the channels you want are checked
- Click “Save and continue”
After this does not fix the problem and users post about it online the forum/reddit TabloTV account responds that:
Sending a screenshot or photo of the channels IN the guide but without data should get them what they need.
You can also specifically ask them to open a ticket with Gracenote (our guide provider) on your behalf.
Doing that gets a response, completely ignoring the issue
I request you to please power cycle the Tablo and then try removing the channel and adding it back and let me know how it goes.
Explaining that step was already completed, did not help, and that this exact same guide information issue has happened on two Gen 4 devices, proving that the issue has nothing to do with removing/scanning/adding channels.
Gets completely ignored by support.
Reaching out via reddit, this response
send me your ticket number or DM me your email address I can have our head of support review your tickets and work to get things resolved for you.
Which sounds great until the customer service manager wants remote access to the Tablo (something not mentioned by official Tablo account, nor any other post)
I will need access to your Tablo to collect additional channel information, once I have this through a remote session I can send the information directly to our guide data provider to further investigate the channels.
To setup your Tablo for remote access:
Press the reset button 3 times rapidly (3 times within 1 second).
If done correctly, you’ll notice your LED will begin blinking twice in a row, with a small pause (heartbeat mode).
The trick to remote access mode is to watch the blue status LED of the Tablo for ~1 minute after you try this. If the blue LED goes solid, it didn’t work and you need to try again. The most common reason for this not working is if you did not click the reset button 3 time quickly enough. This needs to be very fast.
During this time, the Tablo will work entirely normally. The session will last until one of us reboots the Tablo.
Let me know when you’ve done this, and we’ll log in and take a look.
Asking what information they need that requires remote access to my device, and why it is so complicated for someone at Tablo or Gracenote to look at the master database and verify that the program listings for these channels is missing.
Sparked this response from the manager
We must have remote access in order to fulfil your request, there is no other option.
Please let us know when this is done
After responding that it was unacceptable to ignore my questions.
We need specific data our provider requires to investigate the broadcast information. I do not have any other specifics to share with you.
If you wish to troubleshoot with our team we need remote access, if you are not able to give us remote access we will be closing out this ticket.
Other users that have pursued getting missing guide information corrected:
Was your experience similar?
Did you need to grant remote access to your device?
Did they ever fix your issue?
