I wanted to post some observations I have had in the past few days with Dish.TV. I was able to get a beta invite, and I have notices some really killer features that are very simple from a UI standpoint but more importantly would add a TON of value to TabloTV!. Hopefully this isn’t a dupe post going on somewhere else, and if it is @TabloTV please move.
Sound good; waiting for my invite. Only wish they had a way to DVR the shows.
Does the image preview work on all the channels, or just certain ones?
Actually there is EPG from the stand point you can see what is playing on a particular channel. Click on the name of the channel… When you go into All channels for instance, left arrow to the name of the channel hit ok
@snowcat it works on all the channels, but it is like an image for every 5-10 seconds or so. I don’t really think it is as good as Netflix or Amazon, but still it is something
Sling.TV isn’t OTA… it’s over the wire. Big difference. It’s not that different from the online streaming TV channels available when you can prove your subscription. It’s confusing… you bet. Just wanted to let you know why some things will be possible with Sling.TV that can’t be done easily with an OTA grabber device like TabloTV. They are very different.
Also PiX64 your #1, when I hit the up or down arrow it moves to the channel either up or down. It doesn’t really show me much. Although I do see the space when I move
I do want to add that the speed of moving back and fast forward is extremely fast. That is impressive.
Sling.TV isn't OTA... it's over the wire. Big difference. It's not that different from the online streaming TV channels available when you can prove your subscription. It's confusing... you bet. Just wanted to let you know why some things will be possible with Sling.TV that can't be done easily with an OTA grabber device like TabloTV. They are very different.whos was this directed at exactly?
@PiX64 yes I am Roku 3 also, that is strange
@snowcat, it works on all channels i have tried
so I know that ESPN (which i haven’t really tried as i don’t watch sports all that often) for example doesn’t allow for ffw and rewind, so it would not work on those channels.
@Jestep - so if you are in full screen mode watching a show and you hit ok— it doesn’t bring up the main screen “guide” of all the shows while the show continues to play in the background?
@PiX64 No, it shows me what is currently playing and allows me to click down arrow to see more on that show. Once I click the down arrow It shows me * MENU <- BACK and whatever info on that particular show.
Oh unless you pay the $5 for Disney you don’t get ABC either… So only 12 channels
thats way different than what im running… i wonder if you have an older beta or something. i just installed mine last night when i got the email.
@snowcat, so disregard my previous… The rewind does not work on all channels… As an example, TNT does not allow it… Or at least for the current show I am watching.
I just shot a quick video to show what I was trying to explain
@PiX64 yea, now that I have the new app I see exactly that…
The Sling TV app looks great. If it was a little less expensive I’d probably bite. BTW, what type of dog do I see reflected in your fireplace doors?
