Samsung QLED 55" smart TV connected by WiFi to router, latest Tablo app. and 4th gen 4 tuner box connected by WiFi to the same router, which has the WAN connection. All the TV channels are scanned and working, the EPG is populated. Almost all channels are 4 green boxes for signal strength.
Often when opening the Tablo app, it goes through the opening screen, then the top menu will appear with Live etc. and the busy wheel in the center goes into spinorama mode. About one times in 4 it never stops. Stuck there. Ditto for moving over to Library to watch a recording. It often just spins. The TV remote 'back" button is ignored. Use TV remote “home” button to exit and then restart the app, straight back to perpetual spinning. Power the TV off and on, Tablo will be spinning. Go into the TV App page, click and hold over the Tablo app and Reinstall. Then I can start Tablo and usually it won’t be spinning and I can view live or recorded shows. This happens when the prior channel is a 4 green strength channel that is totally solid when watching it, so it’s not a TV signal issue.
Can you confirm you have good wireless signal to your TV? Run InSSIDer on your laptop and confirm WiFi is splashing in that area. Anything above -73 is the start of low signal.
Tablo is a Client to Client transfer, so it puts more of a load on the WiFi.
I was researching why my Home Assistant reports wifi Signal Strength as a percent instead of dBm and ran into this chart. Very helpful in this case…
Understanding wifi dBm readings:
-30 dBm: A perfect, extremely strong signal (e.g., right next to the router).
-50 dBm: Excellent signal, ideal for all activities.
-60 dBm: Good, reliable strength.
-67 dBm: Minimum for reliable online services.
-70 dBm: Okay, but expect slowdowns.
-80 dBm: Weak signal, significant buffering.
-90 dBm: Very weak, likely disconnected.
This is our typical signal strength while using the FireTV Stick 4k Max…right about -62 dBm (if that’s what 62% means), which is good but not great. Not much room for signal loss.
The TV and the Tablo are both on WiFi BOLTON5 network. This is the 5GHz channel on the router, Asus RT-AX86U Pro router running Asuswrt-Merlin 3006.102.6 firmware, the latest.
I think I have to revise my previous post. After digging further, I found that some vendors use % as their measure of network strength (stoopid Netgear Orbi). It’s not easily converted to dBm, so I used InSSIDer and it shows -35 for the high end at the TV and -50 dBm on the lower side when I put the laptop screen behind the TV (where the FireTV Stick is located). So, my signal is stronger than I thought.
Router WiFi 5GHz channel 153 made no difference. If anything, the signal strength was slightly lower. Still get Tablo app spinorama mode that goes away temporarily when the app is reinstalled. I set the router back to Auto and it likes channel 36.
I did install Tablo on the phone for the inital intall, but don’t use it for viewing. Just now I tried tuning to live TV, then watching a recording, going back and forth, no problem at all. The live EPG comes up immediately, don’t even see the spinorama. Opening the Library menu I see a spin for maybe 1/4 second, then its gone and everything is as it should be. The phone is on the same router WiFi as everything else. Thanks for the suggestion, it confirms again that there is good WiFi.
MY Samsung s90f experiences random issues with Tablo 4th generation app. It is connected 5g WiFi just like my iPhone and Rokus but the Samsung will just spin occasionally but my other devices work just fine. On Sunday I had to mirror my iPhone Tablo session to my Samsung so I could watch the football game. THe Samsung never supports offline mode where the iPhone does (I had added an enhancement request in a previous post to give us clients the option to go into offline mode ourselves). There definitely is something not working correctly with the Samsung app. I’m willing to help support work on this but someone has to reach out to me.
Are there any humans answering the Tablo official support emails? I swear the replies are all AI generated. The replies come back in seconds after I send an email, faster than a human can type.
I have the exact same problem on my Samsung Smart TV. I find that if I exit the Tablo app before using another app, then The Tablo app does not just sit and spin. If the Tablo app is left running before switching apps or turning of the TV, then the Tablo app just sits and spins the next time I try using the Tablo app.
FYI: Tablo app on the iPhone works perfectly. No problems on the iPhone.
Looks like a bug in the Samsung Tablo App to me. Does not play well with the Samsung TV OS.
I think smart TV’s get the weakest level of update support compared to Roku, Fire, Android, and iOS devices. You might be better served to get a Roku, Fire, or Onn streaming device.
Support for these streaming devices usually lasts much longer (many years) while manufacturer support for their TV sets dwindles after a year or two as new models and technologies emerge.
We don’t use any smart TV options on our Samsung and don’t even connect it to the network b/c of privacy concerns.
I just installed the Tablo today on my Samsung 2022 QLED TV and all seemed good until I actually went to record a program. All I got was the “spinorama” as you described. Then it came up with a not very helpful message “Back”. Clicking on this did stop the spinning but nothing else - couldn’t start recording. After coming to this forum and seeing your and others issues with Samsung TV’s I’m not planning on spending any more time trying to make this work. The forum is filled with many, many issues and very little evidence that they are being addressed by the company. Not worth the effort and time. And, Samsung TV’s wouldn’t even need this if they didn’t prevent recording OTA programs in the US and Canada (for no apparent reason) as the TV has this native functionality already built in. I’ve been a Tivo user for many years and have come to appreciate timeshifting OTA programs, but my Tivo started acting up and I thought maybe Tablo would be the answer. Unfortunately, not.
I siwtched to using a hack for Plex and never use the Tablo app on the TV. The hack is not so easy to install on the Plex server PC, but once done, it’s done and never needs touching, it just works. Now I can watch Tablo live TV via Plex, and schedule live TV recordings using Plex with all the Plex features e.g. remove ads. It’s a shame the Tablo has no support, but that’s what it is.
From what you’re saying though, this only happens when you record a program, yes? Does it happen every time you try to set a recording? What happens when you try to set up a recording with your phone?
Yes, I can bring up the Tablo app on the TV without any issues and navigate around in it. It happens when selecting a particular program, in this case it was a soccer game on Fox.
I have a very stable, high speed TP-Link Deco mesh network and my Tablo is plugged directly into my router so I know it has nothing to do with my LAN. We watch many streaming shows without any issues on our Samsung, so I know it has nothing to do with my TV’s LAN connection. Even, if I can get it to work on my phone, that’s of no value, since I purchased the Tablo specifically for the Samsung, and specifically because it was advertised to work on this brand and model.
