As a result of the recent firmware update, and a great deal of time which I spent regaining use of my 2 Tablos, I decided to replace the older of my two units, a two tuner box, with a new Quad 4 tuner unit. I installed the new Quad Tablo this afternoon.
During the installation, the new unit shows a 30 day trial subscription to the EPG Electronic Program Guide. My lifetime subscription for my 2 current Tablos shows up correctly in my Tablo account.
It appears that adding this new quad Tablo would require establishing a new monthly, yearly, or lifetime subscription, each with their associated costs of approximately $5, $50, or $150 respectively.
I have two questions:
Is there a way to replace one of my older Tablos with the new quad, continuing to use my original lifetime subscription as is?
Should I wish to instead add the new quad unit as a third Tablo, thus allowing me to keep the original 2 tuner unit as a backup should future firmware updates or other circumstances necessitate, is there a way to avoid starting a second subscription and its associated costs?
Thanks very much for any information and advice.
