There is one channel in my area with an occasional weak signal. It is the CBS affiliate, so there are several programs I would like to record. However, when trying to record the Tablo will reboot if the signal falls below an acceptable level. This not only cancels that recoding, but “splits” any other program being recorded at the time. I can understand cancelling a poor recording, but why reboot and mess up other concurrent recordings? Can’t this be avoided?
I have the same issue. If I select a channel with a weak signal, it reboots. A weak signal should NOT cause a reboot of the Tablo.
Too many issues can cause a weak signal and a reboot should not be the solution.
