Our home is a two story detached home with 2500 Sq, Ft. The current Rogers router is in the NE corner of the main floor in the family room where the main TV is located. The second TV is upstairs in a bedroom in the SW corner of the upper level. The Mac computer is in the NE corner of the upper level above the family room. WIFI is currently available in the whole house.
I had intended on locating the router in the same location as the Rogers router.
I donât use Fire TV Stick, but I believe they are all similar here - you have to click on each picture to see all the episodes available. What to know what you have scheduled, no listing⌠they are highlighted in the daily grid, other wise randomly click on pictures and theyâre in episode order - not recording date order.
Hereâs were Iâve discovered 3rd party apps fill in the voids and aids in productivity, but thatâs me.
Closest thing to what you mean would probably be to sort by Recent instead of All. Youâll get a descending list by date recorded for everything you recorded.
As I await Black Friday deals for the equipment I want to evolve, I did order a Firestick ( New Generation ) for 50% off today. Good deal. Now all I need is for the router and Tablo Quad to go on sale.
Just remember that in order to use Wifi 6 the devices you want to use also have to be Wifi 6 enabled. If you buy this router it will âfuture proofâ you to a certain extent but unless your Firestick, laptop, cell phones, tablets etc support Wifi 6 it will not provide any advantage. Currently the Tablo and Firestick do not have Wifi 6 and it is unlikely that any of your other existing devices have it either.
Thanks for your input on WIFI6. I guess I was just âfuture proofingâ myself as in my lifetime I have been disappointed in how short lived most electronic devices are and the resultant costs to replace them after a couple of years. The tech world seems to move faster than I can think. My thinking was that I could buy a $150 router with 811ac WIFI or a $150 router with 811ax WIFI. Better to be ahead of the obsolescence curve for the same price?
As an example my iMac is now out of the curve for updates including the now released Big Sur release and my iPhone 6S is fast approaching non-support land as well. They still work flawlessly but are now obsolete.
No problem! I agree if the price is similar it is better to get the newer standard. I just wasnât sure where you were on the technology curve to realize what else you needed to do to take advantage of it.
I saw some âmildâ buffering in my son in lawâs setup using Rogers Ignite internet, the fastest speed available, and a Tablo Dual. It was on a live TV program. What causes this and how frequent is it?
The internet service speed is basically irrelevant to this issue. Itâs the speed on the local LAN between the Tablo unit and the TV or streamer box that impacts this. And it really depends on if youâre using hard-wire Ethernet or Wifi.
Donât they pass through the router/switch/access point. So if, for example one is wired an one is WiFi - itâs the wifi device with issues ( or access point)?
The speed of his internet service doesnât matter (it could be 25 Mbps or 1000 Mbps internet and it doesnât matter). This is independent of your WiFi speeds or speed across the Ethernet connections (the local network). This is why I stressed you get a really good router. This way youâre certain no buffering issues.
So now I am understanding the benefit of a very good router for the network within my home. This is the most important part of using the Tablo. The hookup in my home would be like this:
Cable from antenna enters the home where the cable internet enters from the street.
I can hook up the Tablo with an ethernet cable from the router which is connected to the modem provided by the Internet provider where the antenna enters my house and hook up the antenna to the Tablo as well in that location. The two TVâs would have Firesticks and connect via the WIFI network.
Or:
I can hook up the antenna to coax cable which goes to the location of the main TV on the 1st floor and mount the Tablo beside this TV. The Tablo would connect to the antenna at this location and connect to the network via WIFI and communicate with the two Firesticks.
Which would be the better setup with a good router?
