I am new to Tablo and I am having difficulty getting my Verizon FiOS G1100 router setup properly to allow Tablo Connect to work. Does anyone have a good walk through (very basic skill level) or pointers?
I found the website http://portforward.com/ of no real help as they do not have my routher or comparable router under the port forwarding section.
I’ve watched that as well, but there are many options in the drop downs and its not clear what the settings should be. From the app, it looks like I have to change public ports to private ports, but I can’t even locate those public ports in the list of available ports.
Can you please provide a few screenshots of the configuration page for the port forwarding on your router? (you can easily attached images to this forum)
If you haven’t already, you’ll want to create a DHCP reservation for your Tablo, so it always has the same IP address on your LAN. For your router, I believe this is how to do that:
Step 3
Browse to the “Advanced” tab and confirm that you want to proceed. Then click on “IP Address Distribution.” Click on “Connection List” and you’ll see the DHCP connections listed. For example, you’ll see computers listed by “Host Name,” which is the label you used when naming your computer initially.
Step 4
Click on “New Static Connection” and enter the IP address you want to use and the MAC address you obtained in the earlier step. Ignore the “Host Name” field. Click “Apply” and the device with the unique MAC address will be assigned the static address you have requested. Add more by repeating the steps.
Once you have the IP set for the Tablo, go to the Port Forwarding screen in the post above.
Select “Add”
-Select the IP you assigned to the Tablo from the “Select IP from menu” drop-down
-Select Custom from “Application To Forward” drop-down
After you select Custom, an additional drop-down should appear for UDP, TCP, or Both - select the one that Tablo tells you to use
Type in the Port number to forward from what Tablo tells you to use. Enter only one port number here, then click “Apply”
Repeat the process, starting with Add for each additional port to forward.
This youtube should help in conjunction with the above:
@Hickory33 The details above from @ChrisFix should get things up and running. If you run into any issues don’t hesitate to send us an email. We’re happy to work with you to get this running
@TabloSupport, I tried @Hickory33’s details above, and I can not seem to get it to work. I tried the Public Port and Private Port that the Tablo app tells me to use. Please help. It worked before the latest update to the Tablo.
Well, if you use uPNP you let Tablo take care of it and do not set anything up. If you had port forwarding setup then remove that and try what I suggested again. Turn it off, turn it on and then try to turn it on again on the Tablo. It should take care of it…
I found the router not to work the way you think it should via upnp
But, here is a screen shot of how the one I did looks after uPNP took care of the ports
@Jestep@TabloSupport So I unchecked the uPNP and logged out of the router, then turned off the Tablo Connect and quit the Table iOS app. Logged back into the router and turned on the uPNP, then opened the Tablo iOS app and clicked on Tablo Connect… it took about 30 seconds to connect… it worked! Thanks so much for all your help! I can now watch my shows on the go! #TabloRocks Now… if we can get this Apple TV app sooner then later! LOL.
