I have also seen this a couple times after 2.2.8. Weird to see it suddenly start playing after sitting in Pause for awhile. Demonic posession ? Nope. Bad code, quite possibly from Roku.
Please add me to the list of those who are seeing this problem with pause. I have a Roku3 with OS7. After a few minutes (or sometimes seconds), a paused program - either live TV or a recording - will start playing. Most recently, a recording unpaused itself after only a few seconds of “pause”. I experienced this both before and after updating Tablo to 2.2.8.
Tried a test this morning: I turned on Tablo Live TV and paused it. Less than 3 minutes later, the pause cancelled itself. Next, I rebooted the Roku, then repeated. This time the pause lasted a little longer, maybe 8 minutes, before it cancelled itself again.
I have NOT seen this on any other Roku channels (Hulu and PBS Kids).
Hey everyone - Upon further review of Roku’s documentation, our experts have found that this is a limitation of the Roku platform.
Roku devices don’t have an infinite buffer for LIVE streams. What this means is that while you’re watching live TV, Roku will keep requesting segments of the playlist until its pause buffer is full, then it will automatically resume while it dumps the old segments from the buffer to make room for the new ones.
Those streaming at higher resolutions (like 10 Mbps) will see a shorter time window between the pause and the buffer overflowing (2-3 minutes) vs. a lower stream (3 Mbps) where it will be between 20-30 minutes.
Since we cannot control Roku’s root behavior, it’s not possible to generate a fix for this. The only recommendation is to move to a lower recording quality if you need longer than 3 minutes to run to the restroom.
I wasn’t actually watching a live show. I was watching a show that was currently being recorded, on a delay. Like the show started recording at 7:00 PM and I clicked Play on the recording at around 7:10 PM.
It was happening to me about 3-4 minutes into the show.
I’ve had my Tablo for well over a year and this only started happening within the past few weeks.
I haven’t seen this behavior on my Roku with other apps. For example, I’m able to pause an Acorn show indefinitely. Or when using Roku Media Player for a movie I can pause without an automatic play after X minutes.
